Thread: still trouble...
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    Default still trouble...
    re: Stuck at side off road!!! pls help
    Finally getting the chance to try and sort car out now my ankle is getting better.
    started to charge battery last night as was flat from all the 'trying to start car'. i finished charging it last night at 12.27v, i was planning to finish charging this morning to boost it up to about 12.6v, but voltage has dropped over night to 11.97v.
    does the battery need to stabilize or does this mean i have something drawing power from it whilst ignition is off over night???
    could it be a faulty battery???
    what could be drawing power other than interior lights whilst ignition is off???
    many thanks
    East Midlands
    Sounds like the battery has a cell down and its not holding charge.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by macdad View Post
    As above
    Jan 2008
    UK
    would the car be able to jump start with the issue above or will it keep cutting out as the battery wont hold charge??
    East Midlands
    Quote Originally Posted by ADAM123 View Post
    One or both mate,you could get the battery taken into an auto spark ang get him to drop test the battery for a small fee.
    Jul 2010
    Warrington / Liverpool
    The car should run once jumped buddy, assuming your alternator is still good?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yes it shouldn't cut ous as when a diesel is running the on was to turn it of is stop the fuel wich is what the fuel shut of valve does u can run a diesel with no battery on it
    Jan 2008
    UK
    just charged battery to 12.64v. checked voltage and i could see it dropping. within approx 20 seconds it dropped to 12.57v.
    surely a dud battery?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    personaly..id replace it
    Dec 2011
    Seaham
    You got to let the battery rest before checking after charging. However as it did not seem like it was holding the charge before. If you can get hold of a desulphination charger, you may be able to reserect the battery.
    Rapid charging causes sulphination of the plates.
    To properly test a battery, you will to have it checked professionally, they use a load tester. A dud battery can still give out 12v but cannot provide the current.
  1. What next Fan trouble
    By nokiaman1978 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2011, 20:00
  2. Fan trouble
    By xf8u39 in forum Bodywork & Interior
    Last Post: 18th March 2011, 19:06
  3. Im having trouble with my
    By dannyjpuk in forum General Chat
    Last Post: 9th June 2010, 16:42
  4. Car trouble
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2009, 18:26
