Thread: fuse blowen
    Regular Member richardcee's Avatar
    Feb 2012
    Falkirk
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.9 CDTI 16v Turbo
    Year : 57
    Mileage : 69473
    Default fuse blowen
    hi there need some help the now i was changing a blub in my motor and ive blown a fuse but i dont know what fuse it is it was the glove box bulb i was changing help plz
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I did something similar a while back when I was installing my LED strip lights in the boot and ended up blowing fuse 12 in the fusebox on the end of the dash (pasenger side)
    Fuse 12 is for the Battery Control Unit
    Attachment 51756
    Attachment 51757
    Attachment 51758
    Attachment 51759
    Not 100% sure it'll be the same but should help point you in the right direction
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    Sorry for hi-jacking but anyone know what fuse itis for the rear windscreen heater??
    Mines isnt working at the min and hoping its just a fuse
    Year : 55
    Mileage : 92,000
    Heated rear window is Fuse 4 (40amp) in the rear fusebox according to my Haynes manual & pics above
    Already replaced:-
    Alternator,
    Jul 2011
    cheers damo ill hav a look in a bit
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    The power for the heated rear screen is fed via Fuse F30 (60A) in the Engine fusebox, then via fuse F4 (40A) and relay K7 in the Rear Electrical Centre (REC).
    The rear window heater is controled via the Low Speed Canbus from the switch, and then the rear electronic control unit, near the fuses and relay in the REC, operates the K7 relay.
  1. Fuse box
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 15th April 2012, 13:01
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  4. fuse box ID
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2009, 13:17
  5. Which fuse?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2007, 09:41
vectra c f4 fuse in boot
