Results 1 to 3 of 3
Thread: Brake sensor problem?
    Regular Member blacksapphire's Avatar
    Feb 2012
    Forfar, Scotland
    Default Brake sensor problem?
    Been having the 'brake pad' wear indictor appear intermittantly on the dash but it goes out when ignition goes off then on again. Also new brake pads were fitted before i got car--they are like new as i have already checked. Also cannot see any bare wires or anything out of place---have even checked the plug. Could it be a faulty sensor or something else. Have looked/searched on here but no mention of this sensor. Any help appreciated guys.
    Cheers Andy
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's common for the wires to break inside them mate, replacements are less than a tenner. Alternativly you can cut out the sensor and joint the wires
    Feb 2012
    Forfar, Scotland
    Thanks for the help John---when the weather warms up will double check them again
  2. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
  3. Brake pad sensor
    By benwalters82 in forum Suspension, Wheels & Brakes
    Last Post: 22nd July 2010, 18:43
  4. Brake pad sensor - where does it go??
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2010, 17:54
  5. Brake Pad Sensor.. How far can I go?
    By aaruck in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2008, 19:18
