Results 1 to 10 of 16
Thread: cooling bleed screw
    Regular Member Alerxt's Avatar
    Wolverhampton
    Angry cooling bleed screw
    I have a slight leak coming from the cooling system bleed screw at the moment . I have called the dealers about whether its available seperately and guess what NO IT ISN'T!!! . I'll have to buy the whole pipe £121 .
    Just wondered if anyone has replaced the valve with a bolt or something more sturdier than that stupid plastic screw ?
    thank you in advance .
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Can you not ptfe on it and see if it stops the leak?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Take it out and fit a short bolt matching thread size
    Regular Member vekky c's Avatar
    Feb 2012
    galway ireland
    i wrung the head on mine when i was having trouble with the car boiling over and i got a bolt to fit it about 9 months ago ,at the time i said it will do for a week and its still there ,just make sure the threads are the same and maybe a small bit of plumbers tape,the only down fall with a bolt is you cant really bleed the system of air without fully loosening the bolt,alright when cold but not alright when 80 degrees
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    mine is seeping too, left it alone for the very reason of not being able to get the bleed screw seperatley
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    PTFE or Loctite String!
    Wolverhampton
    Thanks guys for the replies . would you believe i've just checked it and no water coming out but i would still like to replace it as its not tightening up just going round and round seems a stupid idea a bit like plastic dipsticks lol
    Wolverhampton
    Quote Originally Posted by vekky c View Post
    any idea what size that bolt is ?
    Feb 2012
    galway ireland
    Quote Originally Posted by Alerxt View Post
    sorry mate not a clue had a bucket of old bolts beside me just kept trying different ones
    Wolverhampton
    my bucket of bolts is sitting on the drive lol
  1. Rounded Clutch Bleed Screw
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2012, 19:06
  2. coolant bleed screw
    By Allan-DTI in forum Engine & Drivetrain
    Last Post: 13th December 2012, 19:28
  3. Z30DT - How do I bleed air from the cooling system
    By ph67 in forum Y & Z30DT Specific
    Last Post: 6th August 2012, 15:22
  4. Rounded off bleed screw - rear caliper
    By 19CDTi in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2012, 10:34
  5. LCD bleed
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 18:49
vauxhall vectra coolant bleed crew
vauxhall bleed plastic screw
how to get plastic bleed screw out from vauxhall
what size thread is vectra bleed screw for coolant
