Results 1 to 8 of 8
Thread: how to change a turbo
    Aug 2011
    widnes
    Default how to change a turbo
    i have a vectra 2.0t with a nackered turbo but i have the same turbo that work but how do i change it does it just bolt of and bolt back on
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    yes mate, if your using the same type.. for yours it will quite an easy job...
    Aug 2011
    widnes
    cheers mate also the other day alll my light on my dash went off and the speedos fuel gauges etc but then next day was fine ant ideas what that could have been
    Regular Member 6009tristanb's Avatar
    May 2011
    bispham, blackpool
    i thought the oil and water goes through the turbo if thats the case theirs a bit more work than just unbolt turbo and rebolt it back on
    Aug 2011
    widnes
    this was on my other vec which runs perfect all that happened was the dash went off i was on the motorway and drove it home with out any problems then wen i strated the car the next day everything came back on
    Aug 2010
    Leeds
    Quote Originally Posted by vectraedition100 View Post
    Check instrument fuse it's a common one on the c to drop out.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    its a low pressure garrett turbo so no water lines, just an oil feed...
    unbolt downpipe, remove air intake pipe, unbolt oil feel and oil drain pipes, unbolt turbo from manifold... refit is reverse of that... not much to it really
    pour fresh oil direct into the the turbo oil intake to lube it properly before reinstalling the oil feed.. This is important, you do not want to start the engine with a dry turbo.. however if your fitting a secondhand unit it will already have some residual oil in it so will not be dry.. bad oil is biggest killer of turbos...
    Aug 2011
    widnes
    cheers mate
  1. Oil Change 2.0 Turbo
    By Mark2.2 in forum Engine & Drivetrain
    Last Post: 4th November 2016, 17:03
  2. Turbo Change
    By tommy1976 in forum Petrol Engine related
    Last Post: 3rd April 2011, 00:49
  3. 2.2 dti turbo change
    By luckyracer in forum Engine & Drivetrain
    Last Post: 30th May 2010, 11:25
  4. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
  5. Turbo oil change
    By mark1319 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2007, 20:30
