Thread: interior light not working
    Feb 2012
    glasgow
    Default interior light not working
    hi everyone, bought 04 plate 2l deisel vectra two weeks ago and cant get interior light working. i have checked fuses and replaced bulbs but no joy, according to haynes manual wiring diagram a relay may be to blame . iam stumped. the glovebox light and luggage light both work, any help or advice would be greatly appreciated, thanks
    Engine : 1.9 CDTi
    Checked the connectors on the back of the light?
    Feb 2012
    glasgow
    tried yesterday mate, could only remove lens , and plastic panel to the rear of the lens, could only see ribbon cable and was unable to remove entire panel even though i had removed the 3 hex screws. to be honest i did'nt want to force unit out in case i broke it, so i never got access to connections other than blindly putting my hand into space obove them and touching them.
    PRESTON
    Having the same problem, front and rear interior lights and sun visor mirror lights don't work, either on the switch or when the door is opened.I believe it may be a fault with the bcm or rec. I have found the two ribbon cables in the rec for the interior lights, there are 5 cables in the ribbon leading to the rear light and 8 cables in the ribbon, leading to the front light. Does anyone know which of these wires do what, so i can test the output of the rec, ie which wire is negative, which is permanant live etc. Also, do any of the fuses in the rec control the interior lights, all the fuses in the dash fusebox, f7, f12 etc are all ok. Everything works except the interior lights!!!!
    PRESTON
    jilava
    I have the exact same problem. Did you guys found the problem?
    Aug 2012
    Staffordshire
    Having the same issue here, vectra estate 1.9cdti
    Regular Member althion's Avatar
    Apr 2012
    lancashire
    Engine : 1.9 CDTI 150
    could be a fault with the roof loom
    Mar 2013
    Norwich
    Vehicle : vectra
    Trim : sx
    Engine : 1.8
    Take a look at the roof loom for any problems like this mine is broken
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by mattysvectra View Post
    Its about 18 months old this thread lol
    but still good advise all the same
  1. Vectra rear interior light not working
    By Steve 100 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 13:42
  2. my alarm sensor and interior light not working
    By nonpris in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2012, 22:57
  3. Interior light not working
    By Jock-W in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2012, 21:21
  4. I now have a working rear interior light
    By rob warrington in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2012, 16:55
  5. Rear door - No electric window or interior light but Central Locking working!
    By siw8158 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 23:41
why wont my interior light work in Vauxhall Vectra 04 I put new bulbs hid still dont work
vectra c interior light not working
vauxhall vectra c interior light front
vauxhall vectra interior light not working
interior light on a Vauxhall Vectra 04 not working what can it be the fuse and where is the fuse
vectra c interior lights not working
what number fuse for interior lights in a Vauxhall Vectra 04 plate please what number
Vauxhall Vectra 04 plate what fuse is it for the interior light what number is it
Vauxhall Vectra 04 plate interior light not working wheres the fuse for
vauxhall vectra c estate front interior light not working
04 plate Vauxhall Vectra in interior lights not working wheres the fuse for Ill put new bulbs in
Vauxhall Vectra 04 plate interior light not working put new bulbs in with fuse
why is not a interior lights on 04 Vauxhall Vectra not working and where is the fuse for it
new bulbs in the interior light on a Vauxhall Vectra 04 plate there still not working
vauxhall vectra interior light not working even with new unit
interior light not working in vauxhall vectra 1.9 cdti
