Thread: rear wiper not working?
    New Member crinks85's Avatar
    Feb 2012
    high etherley
    Default rear wiper not working?
    cannot seem to work out why the rear wiper isnt working, i have checked fuses, removed boot cover and wires and motor look spot on. the stalk works fine an deven makes the quiet noise to say its been switched on.
    has anyone got any ideas or does it look like its a new motor.
    cheers
    Regular Member woody in shetland's Avatar
    Shetland Islands
    Trim : Sxi
    Engine : 2.2 dti
    Year : 2002
    I really hope you get down to the bottom of this as you describe the excact same symptoms as me right down to the stalk making the noise to say it's been activated, i was told mine could be a faulty CIM module by a fellow forum member, i'm thinking to check my roof loom, although iv'e not had the roof lining down before i wonder if the ribbon loom has chafed through or something. apart from that
    Out of interest, do you have any other problems with the wiring as mine does.
    The little orange light under the mirror stopped working + the auto dim mirror no longer dims
    The boot light stopped working.
    All these happened at approx the same time
    Dec 2011
    Seaham
    Have you checked for power at the motor end? Use a multimeter or a test bulb to see if you are indeed getting power. Check the relay?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by crinks85 View Post
    cheers
    Have you checked the motor with a multi-meter when the wiper is on, to make sure it is getting power?
  1. Rear wiper not working
    By Vectra- in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2011, 20:13
  2. Rear Wiper not working. help
    By Ayrcomm in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:01
  3. Rear wiper stopped working!!
    By marwen in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 21:29
  4. wiper not working???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2008, 18:10
  5. Rear Wiper Not Working
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st August 2008, 15:57
vauxhall vectra rear wiper not working
