Thread: Question about my air con
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Question Question about my air con
    Can someone please confirm whether I am being fed bull**** or not....
    I have been told that my air con will not come on if the outside temp is too cold, only when the temp rises slightly. Now, my reason for asking is because when i tried it the other day (outside temp was around 0c) I really couldn't notice the difference. I've put 50 quid aside to get it regassed in srping time but if it's just a case that it won't come on until the temp rises then i'll blow the 50 quid on other bits instead (I have a list as long as me arm! )
    appreciate any advice.....
    Yes it's not
    ijk571
    Guest
    Think in right I'm saying it's 4C
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Put mine on at -10 last month and used it to demist the screen.
    Mine is heard to kick in whatever the outside temp
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    It might click in but at 3o and lower wont be for long cause there is no point so will turn off even with light on.
    Oct 2009
    Aberdeenshire
    do you get the drop in revs and hear the engine struggle a bit when below 4C? if not the compressor is actually not doing anything.
    Jan 2012
    Derby
    Well I tried it today (at a toasty 6.5c outside temp) and I heard it kick in, but again no really no difference in coldness whether the air con is on or off. I guess I'll just have to wait for the weather to warm a bit!
    Engine : 1.9 CDTi
    If you want to see if its working just look at the end of the aircon pump.
    If the centre of the pulley is spinning (Not the outer part the belt is on) when you turn it on it should be working.
    Like this: www.youtube.com/watch?v=kp8pXmlFq_w
    11 Post(s)
    Quote Originally Posted by tony-1977 View Post
    That'll be the dehumidifying part of the AC system working, not the AC system itself. It's designed not to work at something less that 4 deg C to stop itself freezing up.
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
