Thread: bad shock or weak spring?
    Regular Member vekky c's Avatar
    Feb 2012
    galway ireland
    Default bad shock or weak spring?
    hi lads i have the car stripped abroad in the shed i noticed the gap from the wheel to the arch was tighter on one side in the rear and after reading the thread on broken springs i said i better take a look.i took out both springs to have a look at them and they are both the same heigth on the bench and they seem the same when trying to push down on them,i can move both about 3/4 inch,so i think they are fine.then i took out the two shocks and they seem fine,takes a nice bit of pressure to close them and when released they both return the same time, takes about 5 seconds. so now what do i do ?i had to strip the back anyway to change the top control arm on one side so got that done and i changed the camber on both sides to the max aswel because it was eating tyres,its a sxi so sports suspension and its running on 18s oh and i painted the callipers while i was at it .i have the car two years and never new anything about the trouble they have with springs
    any ideas would be helpful thanks
    Dec 2011
    Seaham
    Ride height is generally down to the springs, although they are the same height outside of the car and you can push them noth down equally, you will not be able to put the same weight on them as if they were on a car.
    One spring appears to be weaker then the other, so I would suggest replacing with a new pair.
    Feb 2012
    galway ireland
    can sri springs be got in a motor factors or is it just main dealer
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Springs should be changed in pairs.. One might be a really old one and the other could be a new one giving a different ride height. ????? Just a thought!
    Feb 2012
    galway ireland
    that could be it alright. if i measure from the underside of the wheel arch to the center of the wheel and compare it with someone with a standard sri suspension it should tell me if they are both weak or just one.all i need now is someone who is willing to measure theres for me so i can compare them.please can anyone do this for me it will only take a second.wheel size shouldnt make a difference since we are measuring to the centre.......any takers il buy ya a pint
  1. Christmas Dr Who = Weak too
    By HITFACTORY1403 in forum General Chat
    Last Post: 30th December 2011, 18:09
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. 2.2DTi brake disc size upgrade and shock and spring replacement
    By Mogsy007 in forum Handling & Braking
    Last Post: 14th February 2010, 13:25
  4. Spring shock!
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2008, 20:03
  5. Weak at the knees
    By Spikey© in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2006, 09:31
