Thread: Spark plugs and coil pack
    Regular Member pogvec's Avatar
    Nov 2011
    Uk
    Default Spark plugs and coil pack
    After finding out today that my car has a misfire on cylinder 4 I have been looking at getting a new coil pack and a set of speak plugs!
    Been told that a new coil pack is about £140 + Vat. Been looking at them on e-bay and found this [ame="http://www.ebay.co.uk/itm/200712580595?redirect=mobile"]VECTRA C SRI 2.2 COIL PACK | eBay[/ame] it has the same bosch and vauxhall numbers on as mine. Is it ok to buy a second hand one and is the price ok?
    What are the better plugs to use vauxhall ones or a set fron halfords (I have a trade card)
    The cars a standard 2.2 direct on a 04 plate
    Thanks!
    Regular Member simon7257's Avatar
    reading
    seems ok for that price maybe worth a gamble at least if you buy new you get a years warrenty, id be conserned at how long that coil lasts if the plugs wernt changed often it may not last long, with the plugs i would go for vauxhall or the expensive halfrauds ones
    Nov 2011
    Uk
    Pm I've also been looking at new ones found this one http://www.ebay.co.uk/itm/Vauxhall-S...c#ht_794wt_689
    The Bosch code is the same and so is the engine code z22yh the same as mine but the vauxhall part number not!
    would it be alright or do I Need the vauxhall code to match aswell?
    Nov 2011
    Uk
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Have you had the codes read mate? Id get that done before you splash out on any parts, even the HP pump can cause misfires on the direct and thats a very common falure on the z22yh.
    Nov 2011
    Uk
    Yes mate had the code read today and it came back with p0304 - cylinder 4 misfire
    Was told by the garage new coil pack and plugs!
    Jun 2009
    Middlesex
    I too have an (04 reg) 2.2 Direct and want to change the plugs.The car has done 93.000 miles on the same set but i'm wary about lifting off the coil pack to gain access to be plugs and possibily causing a problem.I know a little about cars but not loads.If i do change them i myself will go for the VX type.
    Nov 2011
    Uk
    It's easy to ehange the plugs fella I changed the coil and plugs for new ones today!
    For the coil pack just unplug it and undo the 4 bolts holding it and it just lifts out!
    Only took about 15 minutes and i hope it's sorted the problem (no codes show now!)
    Nov 2011
    Uk
    Double post
    Jun 2009
    Middlesex
    Thanks for that,as i said i would like to change the plugs but not to sure how to do it.Can u tell me what is involved since we both have the 2.2 Direct (z22zh).Does the coil pack lift off the top of the plugs o.k and what is needed to get the plugs out because i heard they are deep into the engine.
    Thanks Dobs.
  1. New coil pack or Plugs
    By Niall83 in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 20:36
  2. Check coil pack/spark plugs Signum 2.2 direct
    By siross69 in forum Engine & Drivetrain
    Last Post: 17th May 2012, 15:00
  3. Coil Pack & Plugs
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 23:43
  4. Spark plugs, coil pack and rocker cover gasket
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2012, 19:12
  5. plugs or coil pack help!!!!!!!
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2009, 00:31
how to take 2005 vauxhall vectra c spark plugs out
