Thread: Better bulbs
    Full Member
    Nov 2009
    Warrington
    Default Better bulbs
    Hiya guys. Just a quick one. I'm sorry if this has been. Overwriting a million times before. Everybody says the headlights on the vec c's are rubbish and as I have agree I've never know on what to do about it. Never took much notice of the hids threads as I don't know much about them. I'm just wondering is there a good set of headlight bulbs I can get or would fitting better brighter (if there is such a thing) I've seen some on lmf website, think their Phillips x treme. Just after an easy solution I guess if there is one. Thanks all
    Regular Member smiler1982's Avatar
    Nov 2011
    Northampton
    Start by adjusting the height of the headlight beam it makes a world of difference.
    Sent from my HTC Desire S
    Full Member
    Nov 2009
    Warrington
    I have tried that tbh. Maybe I should just upgrade them but like I say I don't know much about hids etc. I should look into it. Just thought better bulbs might improve things but not have the expense of upgrading the headlights
    Full Member
    Nov 2009
    Warrington
    also if i do get some super duper bulbs how do i replace bulbs on facelift 58 cdti 150 ive been told its a mare
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    As above, check/raise your beam height first. To change bulbs take the airbox off completely, and unclip and twist out the washer fluid fill tube. That should give you enough space.
    If not it's drop bumper, which isn't as bad as it sounds.
    HiD's are good, but not fully road legal, so if you want to fit better bulbs, go for xenon gas 50% + or better. I'm using Halfrauds, others have found Ring or Nightbreakers good.
    Either way it needs doing.
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. Bulbs Bulbs Bulbs - non-Xenon .. Best performance?
    By Saf_789 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2012, 08:44
  3. 80w bulbs
    By wullie-t27 in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 11:00
  4. LED bulbs
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 09:47
  5. Bulbs!!!
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2007, 14:22
