Results 1 to 10 of 11
Thread: Exhaust - Single to double??
    Regular Member SIIM's Avatar
    Burnley
    Default Exhaust - Single to double??
    I have a 03 2.2 SRI with single exit exhaust. Does anyone know if the twin exit exhaust from a 2.2 Direct will fit????
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    yip no probs mate all you will need is the y branch to take the right hand box plus the twin exit skirt . you will have to cut your exsisting exhaust to fit the y branch
    Burnley
    So am i right in saying that i need:-
    1: A "Y" Branch
    2: Right hand box
    3: Skirt insert
    4: Heat shield
    5: Get someone to modify the existing left hand box
    Are all of the parts are available from the dealers??
    Leicester
    Here is what you need, the left hand silencer is the original removed from the car, so you need the right hand box from the 2.2 direct, part number 13156933, this retails at £171.08. You will also need the Y section from Irmscher,which is about £115 and comes with the appropriate clamps and instructions. The last thing is either the VXR skirt, or the 2.2 direct SRi twin exit skirt. That is it!!
    You will not need to modify your existing left hand box as the irmscher Y section will be a direct fit, just ensure you ask for a y section for the NON 2.2 direct. As original 2.2's hand only the left box, Irmscher do a Y section if you were converting to the twin irmscher box's.
    The right hand heatsheild is not required, all parts are available from your dealer and takes about 25 minutes to convert.
    Burnley
    Matt your a living legend...... thanks again mate
    Regular Member Braggy's Avatar
    Jun 2006
    St Helens
    Matt I am looking to do the same thing with my 2.2 dti but have been told you can have running problems if there is not enought back pressure, where did you get your bits and what were they off?
    spoons
    Guest
    Hi Matt,
    Looking at picture number 4
    I can see what you mean now..... that right hand (offside) box pipe feed is much smaller than the left hand (nearside)... no wonder the 'condensation' appears more obvious through the left hand pipe as its much bigger... and less through the right hand one as its much smaller?? The size difference appears to go from the tailpipe... right through to the 'Y' section..
    Wonder why they've done that ?? Are all twin pipe vectras the same setup ??
    EDIT: I checked mine the other morning and I have completely even 'condensation' through both tailpipes... Does look quite good as you say !!
    Regular Member monkeybusiness's Avatar
    Wirral Merseyside
    I fitted the same system to my 1.8 and it runs superb. Might even sound a bit better! No probs with "back pressure" or uneven flow. And it looks
    sooo good!
    By the way, I have a spare twin exit skirt for sale if anyone is interested. £15 plus postage.
    Jun 2006
    St Helens
    if i can find out which exhaust will fit my 2.2 dti i will have it.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Quote Originally Posted by monkeybusiness View Post
    Interested in that skirt
  1. Replies: 10
    Last Post: 22nd September 2012, 20:26
  2. Which stereo to put in double or single
    By VECTRA1974* in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 14:08
  3. Single or Double
    By signumboy in forum Quick Photo Album
    Last Post: 19th October 2010, 22:58
  4. Single, double, 1.5.........??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2009, 20:39
  5. double din to single
    By jbs1 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2008, 19:46
vectra sri exhaust single to double exit
