Results 1 to 10 of 11
Thread: rear tweeters
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default rear tweeters
    what are the chances of my 07 estate having the rear tweeters, or at least the wiring for them?
    atm i have wind up windows in the back but have managed to source some rear electric switches so while swapping them i may as well throw the tweeters in also?
    are they the same in all vauxhalls do we know?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I didn't have the wiring in my preface, but i did retrofit them quite easily
    The standard tweeters can be fitted to the existing blanking plates.
    Remove the existing blanking plate and pop your hand in the door. If the wiring is already there for it, it won't be hiding far
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by J P S View Post
    If you're fitting the rear electric windows you need to change the door looms anyway and they will have the tweeter connections on them and the new switch panels should have the tweeter housing. All the door tweeters are identical front and rear so you can just obtain a pair and chuck them in.
    Sep 2011
    Birmingham
    Trim : sri
    ok i shall pop one of the blanks out then and see what i can find.
    assuming i need some are they all the same?
    i may even have the ones from my old b somewhere
    Are there no tweeters already fitted to the switches
    Sent from my iPhone using My thumb
    Nov 2011
    Vec B tweeters should fit, or so i've read
    Sep 2011
    Birmingham
    Trim : sri
    Quote Originally Posted by Ian-Highlander View Post
    well i would like to eventually do the rear electric windows but these switches came up with blue leds in so i went for them for now.
    might take me a while to gather all the bits together for rear leccy windows but it is an aim one day.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    If you don't have the wiring, as long as you have the genuine Vec C tweeters (they have the capacitor fitted already), you can just tap a wire onto the back of the door speakers and run it to the tweeter and they will work.
    Sep 2011
    Birmingham
    Trim : sri
    looks like i need to see if the wiring is there first then go from there then.
    damn these dark evenings!
    Nov 2011
    Exactly how i did mine Works a treat!
  1. Will these tweeters fit in the rear doors?
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2011, 22:01
  2. rear tweeters
    By phil0464 in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2009, 21:47
  3. rear door tweeters
    Last Post: 28th March 2009, 22:35
  4. Rear Tweeters Again
    By AndrewTi in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2006, 18:04
  5. Rear Tweeters
    Last Post: 21st March 2006, 00:34
