Results 1 to 10 of 19
Thread: Rear washer blocked
    Jul 2011
    Leeds
    Post Rear washer blocked
    Hi all,
    Can someone tell me how to unblock my rear washer jet? It hasn't been squirting for a while and vaux wanted £25 haha they do tell good jokes!
    Jan 2010
    Liverpool
    Crud has probably worked its way into the pipe. I had this problem and had to remove the jet to clean everything out.
    I found that the filter on the washer motor was knackered and all kinds was getting into it.
    Jul 2011
    Leeds
    How do I sort it? Don't even know where the motor is, do I need a new rear nozzle?
    11 Post(s)
    Try pushing a pin in the nozzle to se if you can clear it.
    If you need to clean the filter, then there is a how2.
    Jul 2011
    Leeds
    I tried pushing a needle but it was too thick, what should I use?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by shiver2k11 View Post
    I used a pin to clear mine. Worked a treat
    Jul 2011
    Leeds
    Post
    tried a pin not shoved it fully in but not cleared, whats next?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Shove it fully in I did. If not, probably need a new jet
    Does the front one work ok? (just to rule out the motor/pump)
    Jul 2011
    Leeds
    Post
    Quote Originally Posted by tony-1977 View Post
    yer front one works. will try the pin again tmz
    Jul 2011
    Leeds
    no hopeless. whats next? lol
  1. Rear Washer jet
    By Vectra-c-SRI in forum Bodywork & Interior
    Last Post: 30th January 2013, 01:04
  2. Rear washer
    By Carl83 in forum Bodywork & Interior
    Last Post: 29th November 2011, 02:09
  3. Where's the rear washer?
    By stoneyloon in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 20:56
  4. rear washer jet
    By bret.c in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 15:04
  5. Rear Washer.
    By ashdog in forum Bodywork & Interior
    Last Post: 27th August 2006, 07:43
how to fix vectra rear wash blockage
how to ublock vectra c rear sprayer
