Results 1 to 10 of 25
Thread: Thermostat location - 2.2 Direct
    Default Thermostat location - 2.2 Direct
    Is this it? And if so, what is the correct temperature stat that I need?
    South east
    It's not so much the temperature you need to worry about, it's the fit - if you buy one designed for your engine then the opening temperature will be correct anyway.
    Thanks.
    Now can anyone confirm the pictures are where the thermostat is?
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    D/K for sure but your pic matches the thermostat housing pictured in my Haynes manual.
    HTH.
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    Double tap. Grrrrrrrr. This is starting to get on my t*ts.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yes mate thats it, I changed mine a couple of months back.
    Thanks for confirming. Couple of other questions:-
    1. Can I just buy the stat on its own, or does it have to be the housing as well?
    2. Are the two 10 mm bolts prone to being siezed and snapping off easily? I'm speaking from experience of changing the stat on an old Cavalier a few years ago. Doesn't look like there is much room to get a drill and tap in there if I needed to.
    Vehicle : SRi
    Mileage : 137000
    Just the stat mate, although the stat could be ok, the seal can perish and let water through that way, it seams to have affected a few older 2.2's. As for the bolts, mines a 53 plate and they cane out fine and ive not seen any others fail on the forums.
    Cheers Rushy.
    Priced up the parts though autovaux - £54.23 (inc vat + p&p), for a stat, seal, and 5 litres of antifreeze.
    My local dealer want £71.46 for the same parts. Just waiting for them to come back to me as to whether they'll accept my Masterfit Service Clubcard which will give me 20% off, which will bring it down to £57.17 (£2.94 more than autovaux). They have done previously, but seem reluctant to do so this time. I did get offered a traders 10% off deal - lol. I asked them why would I want that when my service clubcard will give me 20%?
    Their other dealership 10 miles away is a masterfit outlet, and they said it might be better to order the parts through them to get the 20% discount, although they'll get the parts from us anyway!! Crazy or what.
    I have been told however that the stat from autovaux won't be a genuine Vx one though.
    My dealer gave me the following part numbers:
    Stat 90537811. 94 deg C (£45.12)
    Seal 3522676 (£8.40)
    5 litres of antifreeze £17.94
    Vehicle : SRi
    Mileage : 137000
    The Stat I got from Autovaux was a genuine GM Stat, just ask them, most of the time for parts like that they have gen in. I paid exactly the same as you for all the same parts.
  1. Z20NET Thermostat Location
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 21:58
  2. 3.2 thermostat location
    By Big Sig in forum Engine & Drivetrain
    Last Post: 28th September 2009, 19:49
  3. Thermostat location? Sloppy Stick!
    By stevensred5 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th January 2009, 15:28
  4. 2.2 Direct Engine Number Location
    By Palmo in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2008, 00:35
  5. Thermostat location 2.0dti
    By bran.c in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:20
vectra c z22SE thermostat price
thermastat. vectra c 2.2 petrol
astra 2.2 thermostat location
opel vectra c 2.2 direct 2005 termostat
