Results 1 to 10 of 13
Thread: One Touch Electric Windows Not Working
    Regular Member SteveBray's Avatar
    Barnsley, South Yorkshire
    Unhappy One Touch Electric Windows Not Working
    I noticed recently that my one touch function of the electric windows has stopped working, I have to keep my finger on the button to open or close them. It is not a major issue but has anyone else had it happen, is it easy to resolve or not worth the hassle?
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I had this happen to me last week when I changed the battery on the car.
    Simple to fix........ I think all I did was to wind each window down, then all the way back up. But when the glass reaches the top of the door I continued to hold the button for about another 5 seconds and that seemed to fix it
    Hope it works for you
    EDIT:- Just found in another thread
    Code:
    The correct procedure is:
    1. Close doors.
    2. Switch on ignition.
    3. Open windows completely.
    4. Close window and press on button for at least 3 seconds.
    5. Repeat for each window.
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    South east
    Keep the buton held until the windows close fully and keep the button pressed for a further few seconds. Now press the button to open window fully and keep it pressed for cpl of seconds more even after fully open. One-touch should now be restored.
    Full Member paul.sessions's Avatar
    leighton buzzard
    Brilliant, thank you, I never cease to be amazed at how helpful you all are, this is also the best car forum I have ever known, makes owning a Vectra a better prospect!
    Quote Originally Posted by SteveBray View Post
    Owning a handbook is also handy - ie, it gives the same answer as above
    Surprised by that, thought that kind of information would be reserved for dealers so they can charge for something. I always look in the manual when curious but thought there would be no way anything would cover one touch windows so did not read it. I will remember that and always have a look first in future.
    West
    Had you disconnected the battery or changed the keys recently... i found that you don't actually have to wind the window down then back up, just hold the up button down till you hear the click
    I put the red box on so loosened the positive terminal slightly, guess that's what did it.
    Sep 2010
    my old 08 used to do it now and again without any electrical disturbing - must be fairly common.
  1. electric windows help
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2012, 17:37
  2. One touch windows
    By juggernaut in forum Bodywork & Interior
    Last Post: 8th March 2011, 11:26
  3. Electric window one-touch issue!!
    By Tyger in forum Bodywork & Interior
    Last Post: 9th February 2011, 20:18
  4. One touch windows & total closer NOT WORKING
    By simbob in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2008, 02:01
  5. Electric windows via Key fob
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2008, 16:22
