Results 1 to 10 of 28
Thread: vectra cdti injector problem...
    Feb 2012
    Newcastle upon tyne
    Question vectra cdti injector problem...
    Hello, am a newbie to the vectra c sri cdti 150 just bought a 56 plate veccy and hasnt been off to a good start either... had the car few month now already had a thermosat on it
    BUTTTT now....
    i have a leaking injector on number 3! so after alot of garages saying they wont be able to remove it as it will be locked soilid and other garages wanting £££'s i found a very local garage to me agreed to remove injector mega clean it up! cleaned the bore + new copper washer and new 'O' ring etc etc... and sort my problem out he'd done loads diesels injectors good named garage LONG STORY CUT SHORT!
    (am aTART with my cars wont use any tom,dick or harry btw)
    so as of monday heres whats happened,
    MONDAY round.1 = FAIL! still leaking louder and worse..
    (so took it back next day)
    TUESDAY round.2 = MEGA FAIL i got about 1mile away and car was undrivable had to be towed back to garage..smoke every were!!!
    (leaking worse then ever!!!) was like a train!!!!!!!
    WEDNESDAY round.3 = SUPER FAIL garage can not get injector sealed back in???? rang me to have a look said its not getting a seal we keep trying going to try new stud bolt to get the injector locked in better as my stud (which holds injector in is higher then others??? hmmmm?)..
    Soooo ive had a qwick look/read though search bar and found bits and bobs about injectors but still abit lost on them? whats my best way of action because i'm now carless + fed up and sick to be honest now any ideas ive seen its a common problem is there any good link help tips would be great to pass info on to garage to try?
    who ever put this FIAT engine in my vectra needs shot!!!
    sorry tried my best to explain as am rubbish at explaining things sorry inadvance and obv a re-post,
    Kev
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by betrayed View Post
    Technically it's as much as a GM engine than it is Fiat, it's a result of a failed merger between the two companies a few years ago.
    I guess the only thing you could get them to retry the job. From what i've heard, the copper washers are a pain, but once they're in right, problem sorted
    May 2006
    scotland
    Well, one of my injectors has leaked really since I bought the car 6 years ago. I decided to leave well alone and now it appears to have sealed itself. I blast the car once a week, 4.5K rpm for a few minutes. No problems.
    My motto is, if it is not causing great grief then leave well alone.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are they fitting a new copper washer each time they take it out?
    They may have damaged the seat by cutting too much or something as well.
    Could always try a small bit of exhaust paste. And use it a bit like grinding paste. Using the injector and see if that helps seal it.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double post gremlins
    Feb 2012
    Newcastle upon tyne
    todays update THURSDAY...
    I phoned the garage today to see the progress.. he says the injector leak is fixed but now my cars running on three pots...
    FML...
    so would it have damage my ijector? OR will it need programed in again? or will it be the lines/wires making it run on 3 pots
    any ideas lads?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Perhaps they damaged injector nozzle having it in and out so much.
    Or damaged wiring or something
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Inj no.3 has a known fault with the plug and there is a new plug/loom availabvle from VX.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The leak hasn't been fixed m8 by the sounds of it and I would say if your injector plugs are Yello there is a very good chance that's the problem. There is an issue the old style injector plugs (especially the one on the 3rd injector) start to go bad and dirty and need replaced with the newer upgraded Blue version. This issue causes the car to eventually start shutting down. Dealers can fix them all for about £130. The part istelf is £12 from the dealer. You would need 4 of them if you're going to do all injectors.
    Quote Originally Posted by MrDerv View Post
    Certainly more Fiat m8, Alfa and Fiat have used this engine since 1997 and have developed it ever since. It was the first common rail diesel in a passenger car according to popular links.
  1. 2005 Vectra 1.9 CDTi 150 injector seal
    By MXB74 in forum Engine & Drivetrain
    Last Post: 11th March 2012, 18:38
  2. Cdti injector problem
    By aidy-cdti in forum Engine & Drivetrain
    Last Post: 27th June 2011, 20:19
  3. Vectra V6 CDti Injector problem possibly?
    By smitd004 in forum Engine & Drivetrain
    Last Post: 1st June 2011, 21:14
  4. 2005 Vectra 1900 CDTi 150 Injector Leaking
    Last Post: 2nd February 2011, 23:17
vectra 1.9 cdti leaky injectors www.vectra-c.com
