Thread: is this normal ?
    Regular Member bigbranno9's Avatar
    Jan 2012
    middlesbough
    Default is this normal ?
    just fitted some 6000k h7 hids to my 02 vec c and when they cold they flicker for about 30 seconds and then they are ok is this normal.If i turn them on without the engine running theres no flicker only when cold and i first start the engine thank in advice for your help guys
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    Are you referring to the flickering when the lights are off? If so, you should fit the cancellers which should have come with the kit. If not you may have a faulty set of ballasts. I have a pre-facelift with HIDs fitted (cancellers fitted & CANBUS Pro ballasts) & get no flicker when on or off, just a nice crisp white light, not the tealights i used to have!
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Canbus compatible ballasts will fix the flickering. You will need cancellers too so that the bulb warning won't flash up
    Jan 2012
    middlesbough
    Thanks for your reply no I mean if I start the car from cold and turn the hids on they flicker for about 30 seconds then they are fine
    as if like they are warming up.
    Regular Member weverall's Avatar
    Littleport, Ely, Cambs
    Oh yeh they take a little bit of time to warm up, but i dont think flicker... not to the extent the standards would
    Nov 2011
    Are the ballasts canbus compatible?
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Quote Originally Posted by MrDerv View Post
    Is that the same as a 'Digital Ballast' or is that something different?
    Nov 2011
    All ballasts are digital, but the difference is you'll have normal ballasts (some slimline too), and the canbus ones. Canbus pro ballasts are manufactured to combat canbus issues such as bulb monitoring systems like the Vectra/signum has. Canbus Ballasts stabilize the voltage received (bulbs on the vectra are "pulsed" when switched on, and even when off to ensure there isn't a blown bulb) so they don't flicker during use. A canceller won't simply fix the issue, just turn off the warning on the dash.
    I hope i've explained it easily
    Jan 2012
    Chester
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Yes, that makes sense. Thanks
    Nov 2011
    No worries
  1. Is this normal?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 10th April 2012, 15:10
  2. Normal or Way Out?
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 19:22
  3. is it normal
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 4th January 2012, 22:24
  4. Is in normal?
    By Pulja in forum Diesel Engine related
    Last Post: 28th June 2011, 20:20
  5. ...Is this Normal??
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 18:58
