Results 1 to 10 of 28
Thread: Whats going on???
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default Whats going on???
    After swapping the cd40 opera for the cd70 http://www.vectra-c.com/forum/showthread.php?t=156325 im now having climate control issues!! the climate panel dosnt light up when you start the engine and there is nothing for the heat and fan speed in the display, also the panel seems to be dead, and after a while the panel comes back to life.
    the fan speed and temp then shows in the display but not in bold black like the outside temp or the time (more like a faint gray). the code reader says U2102-00 CAN-BUS (MID SPEED)MAXIMUM CONFIGURATION LIST NOT COMPLETE.. anyone have any ideas??
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Might need to get the variant configuration done with tech 2
    Are you VXR Enough
    13 Post(s)
    Sorry fella but what does that mean?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Telling the car it has a different HU fitted. Some code readers can do this as well.
    scottish region
    Need tech2 mate as climate control should come up on screen
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Yeah as above mate make sure the car knows what it's got basicaly
    Chelmsford
    Where are you mate?
    Are you VXR Enough
    13 Post(s)
    was told this head unit was a easy swap out lol i guess not so basically i need to tell the car what head unit is fitted?
    scottish region
    If u did not have climate control yes but it works with the screen and they will need to be paired
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    what is missing is in the low speed can-bus and maby variant config the screen dont know your car have ECC.
    (the code is not even neede to change that setting)
    And its only in the screen its neede to be change.
  1. Whats in the box
    By bigmac in forum Insignia car chat
    Last Post: 21st September 2011, 18:08
  2. Whats in the box?
    By Ginge7289 in forum Styling
    Last Post: 19th September 2011, 22:00
  3. Another whats in the box..
    By blue estate in forum The 'Off Topic' room
    Last Post: 10th May 2009, 21:54
  4. whats best to use?
    By Mads in forum Detailing and Car Care Discussion
    Last Post: 26th July 2008, 01:04
  5. Whats The Name
    By lilangel in forum General Chat
    Last Post: 8th April 2008, 20:21
u2102 corsa c
u2102 vauxhall
