Thread: water and oil
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Default water and oil
    Good day one and all,
    Got a 1.8 2003 and have a couple of curious issues and just looking for anybodies thoughts / experiences / advice.
    It is losing water/coolant rapidly and also losing oil at a slower rate, not a rocket science question but here's the issue - I have no leaks!!
    Due to have the cam belt, water pump and stat being replaced hopefully real soon - mates rates - and hoping this will cure the water problem but cant explain the oil thang.
    Took the car on a healthy run over weekend - approx 400 miles and it didnt miss a beat and sounded ok, no noisy unusual sounds from engine.
    Cheers for any help.
    Tony
    Dec 2011
    Seaham
    get a pressure test done, its possibly a head gasket issue?
    Do you have any mayo under the oil filler cap?
    Is the exhaoust smoke white or blue after its warmed up??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Suspect head gasket. Early signs of failure
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Thanks for the quick responses.
    Oil and water haven't mixed either way.
    Exhaust smoke - haven't seen a lot tbh but the little bit I think I might of seen is white - but thought that may of been due the choke still in operation.
    The car hasn't been properly run in approx 18 - 24 months prior to me getting it.
    Tony
    Dec 2011
    Seaham
    Check the carpet, you may not have a leak in the engine bay, but possibly one inside the car to the heater matrix?
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Cheers Ben50n, will try that over the weekend - until then will use bike for work!!
    Oh well, I guess these are the teething problems when buying a car without any supplied history and a Cat marker on it!! love a challenge
    Chelmsford
    Check the radiator, edge where the metal meets the plastic section. It's a common place for corrosion to cause a leak.
    How often are you having to top up the oil? Is the warning coming up on the dash?
    11 Post(s)
    Quote Originally Posted by Ben50n View Post
    Do you have any mayo under the oil filler cap??
    At this time of the year most cars will have mayo. Don't mean to say the HG is gone though.
    Before starting off on a 200 mile round trip (mainly motorway) the other day, I wiped the mayo off the filler cap and dipstick of my 2.2 direct. Next day it was back again.
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    Will check rad edge and all over tbh.
    Checked oil before trip and it was on max, about 100 miles into journey the warning light (orange) flashed up on dash, stopped and topped up with 3/4 L and carried on.
    Checked it the following day and topped it back up with the remaining 1/4 L that was left.
    The return trip I got to approx 20 miles from home and topped up again with 3/4 L.
    Def haven't had and mayo on dipstick or filler cap though.
    Cheers for the replies all.
  1. water water everywhere
    By rob warrington in forum The 'Off Topic' room
    Last Post: 9th December 2012, 00:03
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. help.........water!!!
    By lilangel in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2008, 10:49
  4. oil in the water (PLEASE HELP)
    By steve.davies in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2007, 23:17
  5. Water water everywhere!
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2007, 15:09
