Results 1 to 10 of 24
Thread: Tips and hints for de soldering SMD leds
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default Tips and hints for de soldering SMD leds
    Hello
    I am after some tips and hints for desoldering SMD leds as I just tried one of the door switch ones and it was a proper pain to get off as can only do one side at a time, I ended up tearing the track off the positive side but ended up working once I soldered the new led on. Saying that I was using my cheepo 15w iron. Will be getting a proper thermostat regulated soldering station when I do it on a bigger scale.
    Regards
    Dave
    Sent from my iPhone using Tapatalk
    Dec 2011
    Seaham
    You need a de-soldering tool!
    http://www.ebay.co.uk/sch/items/__de...=228459_228459
    Its a vacuum sucker, warm the sodler up on one side, use the de-solderer, then do the other side.
    Simples!
    Dec 2011
    Seaham
    Doh, double post!
    Oct 2010
    Walkden, Manchester
    Yep got one of them, didnt do much to be honest.
    Dec 2011
    Seaham
    It should have sucked the solder straight off! Are you using a small tipped soldering iron? It concentrates the heat into a small point, some of the generqal purpose ones have too large a head.
    http://www.ebay.co.uk/itm/40w-Solder...item20ba431409
    Smething like this will give you pinpoint heat.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The door ones are glues in as well, there the only ones that are a pain, the rest are only held on with solder.
    Oct 2010
    Walkden, Manchester
    Yeah is a fine point tip will be buying one of these at weekend will get better control.
    http://mobile.maplin.co.uk/module.aspx?moduleno=219133
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    You're actually better not to use a desoldering tool for SMD, desoldering tools were really designed for PTH technology. That said, they will work a bit.
    There's 3 ways to remove SMDs:
    1) Use solder braid to remove the solder - this doesn't alway get all of the solder though.
    2) Apply more solder to each side of the device and heat up both sides - don't hold too long on one side though and keep alternating until both sides are fluid enough to remove the device.
    3) Use a hot air gun (special solder ones though, not the big heavy ones because they blow too hard and end up blowing devices all over the place) this is really for QFP etc though and complete overkill for a couple of diodes.
    Oct 2010
    Walkden, Manchester
    Well after watching videos on youtube, I decided to put that knowledge to the test this evening. So I changed the leds in the 4 heater buttons, changed the red and blue on heater temp and changed the drivers door lock/unlock to red and it was alot easier to say the least. Im just waiting for the white leds to arrive so I can started on them.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Patience and a decent soldering iron.... my first attempt trashed my driver door switch after 'ripping' off some of the LED's with my LIDL HUGE chisel tipped soldering iron.... haha talk about the wrong tool for the job!
    Got them all done in the end though and Kman did the tiny ones in the CD70 and the clocks
    My advice... start on the smallest switches as they are the cheapest to replace if they go wrong lol
  1. GT5 Hints and Tricks
    By spennny in forum Games Room
    Last Post: 16th January 2011, 12:19
  2. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  3. How2,hints,tips, on bleeding brakes plz
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 12:21
  4. Hints and Suggestions for the trip
    By plasma in forum Irmscher Factory Road Trip 2008 - 24th-29th April
    Last Post: 18th April 2008, 21:29
  5. detailing help hints and tips please
    Last Post: 7th April 2008, 00:02
vectra c smd door switch
