Results 1 to 2 of 2
Thread: injector pump leak
    ireland
    Default injector pump leak
    hi there , i've recently had a diesel leak and discovered its up around the injector pump'its a sri 150 engine' has anyone came across this before any info or advice would be great thanks in advance
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I'm sure someone else had this not so long ago, all it turned out to be was a loose union nut on the feed pipe.
    Check they are all tight and it should sort it
  1. How do you change leak off pipes and injector seals
    By m.c.jones in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2013, 22:41
  2. 2. Dti Injector pump
    By wilf2312 in forum Engine & Drivetrain
    Last Post: 4th December 2007, 12:59
  3. oil leak from injector tube 2.2dti
    By Beavis in forum Engine & Drivetrain
    Last Post: 11th April 2007, 08:00
  4. Injector Pump
    By efcmandan in forum Engine & Drivetrain
    Last Post: 22nd November 2006, 10:09
