Thread: brakes creaking
    Jul 2011
    retford
    Default brakes creaking
    ive had a creaking noise when coming to standstill on the front brakes for a while. doesnt do it when at speed, just when coasting to junction etc.
    ive depressed pedal by hand and had a listen and i can hear the noise from the drivers wheelarch area.....
    anyone any ideas?
    cheers
    I had this on mine, was diagnosed as a seized front offside caliper
    It was worse when stationery and pressing the footbrake, clearly audible
    Jul 2011
    retford
    right, i now have an annoying permanent sqeak on the brakes, like there dry, ive regreased the pads with copper slip and hasnt made a difference, the creaking is still there as described above but with a permanent sqeak aswell now.
    indicative of caliper seizing aswell, or could it be the slider bolts.
    Regular Member DonnieDubh's Avatar
    Jul 2011
    Fortwilliam Highland
    Could be a small part of the back plate making contact ??
    Dec 2011
    Seaham
    Any build up of rust on the end of the disc rotor? I usually get a small hammer and gently chip away all thick rust from the rotors.
    Careful though as you can shatter a disc rotor if you hit it too hard!!
    Jul 2011
    retford
    it goes away when i brake though, im guessing carrier sliders need a clean and a lube up.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. creaking
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 25th August 2011, 08:13
  3. Creaking brakes 2.2DTI SRi..?
    By bigdave1701 in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2010, 15:36
  4. Creaking sound from Brakes
    By mikaz in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2009, 14:40
  5. Creaking
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 26th November 2008, 18:12
vectra c front brakes creaking
vauxhall vectra creaking brakes
vectra c creaky brakes
vectra gsi creaky brakes
front brakrs creak vectra
vectra c seized front caliper
vauxhall brakes creaking
vauxhall insignia creaking noise when braking
vectra c drivers side brake creaking
