Results 1 to 10 of 14
Thread: expected cost to reknew cambelt and Water pump
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    Default expected cost to reknew cambelt and Water pump
    Afternoon all
    is any one able to provide me with some idea of how much a Cambelt and water pump will cost me from Vauxhall Dealers(wakefield) as the car has done around 65,000 1.9cdti 120, donrt want to risk going to 100,000 as per the manufature state
    any advice would be great
    thanks Craig
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Around £600ish?
    I had mine done from VauxCare Wirral for £245 and that included parts.
    Apr 2006
    Quote Originally Posted by john506 View Post
    Around £600ish?
    John506
    Thanks for that 600ish eek ive seen that they are doing a fixed price £249 for a vectra cambelt change, i gather the pump is expensive then plus labour to fit, do you recomend the pump to be changed at the same time, forgot to say mines a 56 plate
    Mar 2011
    Wirral
    Not the most technical minded but they do recommend changing the pump along with cambelt as they have the same sort of life span. Sometimes your waterpump can go before your cambelt, it will cost you more if you had the cambelt done and then the waterpump at a later date so I'd say go ahead and get waterpump done too.
    Have you had a ring around some local garages instead of the stealers? Maybe get the parts yourself then just ring around for labour costs which might work out cheaper again.
    Apr 2006
    John506
    didnt think about that wasnt sure that local garages would just do the labour would it be best to get GM parts from dealers or non gm parts, sorry for all the questions
    cheers so far mate
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Water pump and tensioners are best changed at same time. As belt rarely fails on its own. And is usually down to failed water pump or tensioner
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    http://www.vectra-c.com/forum/showth...burning+rubber++
    i have a burning smell from the cambelt area i think its my water pump which has seized its on 62000 miles
    i will find out at the week end to take the cambelt casing off
    so i would get the Water pump and tensioner /beltchanged at same time
    West
    I'd say about £250 all in from a decent independent
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Fit a new tentioner and idler aswell.
    Chelmsford
    For the parts go to Eurocarparts.co.uk
    25% discount on many different parts.
    Put service25 in as discount code.
  1. Just had cambelt & water pump done
    By aps in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:46
  2. Cambelt & Water Pump
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2012, 00:48
  3. 3.0 v6 cambelt/water pump
    By bigsteve3.0v6 in forum Y & Z30DT Specific
    Last Post: 11th September 2011, 23:44
  4. 3.2 v6 GSi cambelt and water pump
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2010, 20:07
  5. cost of cambelt and water pump?
    By Adz86 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 16:15
vauxhall 3.2 v6 cambelt cost www.vectra-c.com
