Thread: Please help
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default Please help
    we keep having to bleed our brakes.. we had the front ones changed just over a year ago and ever since then we keep getting air in them, had the pipes looked and they seem fine.. we are NOT losing any brake fluid.. getting fed up with having to bleed them.. it seems the pedal travel (and I mean travel .. push it again to make them hard & work) happens when wet/snow.. my OH reckons its when the traction control light comes on they start getting air in but ive never noticed.. there was no problem with the braking system before they got changed but we knew the fronts needed doing.. what could it be??? it can go for months after bled then all of a sudden it starts, then slowly gets worse..
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Have you tried tightening the banjo bolts?bolt that holds the brake line to caliper?..is the brake/clutch fluid cap on tight?..or is the seal damaged in any way?..
    Nov 2011
    Buckinghamshire
    Quote Originally Posted by nikroc View Post
    Ooo we have to bleed the brakes again this week so we will check.. is it visible the bolt thingy? yeah the cap is on nice and tight
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    The bolt is clearly visible..at the end of the brake line,where it attaches to the caliper.
    West
    do you have any fluid loss
    Chelmsford
    Air in the ABS pump possibly...
    Only way to sort this is to use Tech 2 to open the ABS valves whilst doing a bleed (Op-com doesn't do it for some reason, well mine doesn't!)
    Chelmsford
    re-read the OP..
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    My mate had a similar issue on his golf we bled his brakes a few times with no change then i noticed two bleed nipples under the brake fluid resivoir (on the slave cylinder i think its called) bled the both and it fixed it ,dont know if yours is the same worth a look though!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by DNS View Post
    Or start the engine and bleed the brakes. This is the way I did my dti many a time and always got a good pedal
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Only other suggestion is that either the master or slave cylinder is knackered, in my experience this is a possibility.
    3.2 v6 Signum and loving it
