Thread: unuseal egr valve removal related question ??!!??
    Jan 2012
    largs , scotland
    Default unuseal egr valve removal related question ??!!??
    posted thos elsewhere but thot id get better answers on its own .
    This might be a stupid question as iv not looked in to it at all to see if its even possible just a thot that poped in my head last night , but if you where to blank the egr port on the inlet manifold side and leave the feed pipe open to atmosphere (relocating to under car and removing egr completely) would this act like a cat bypass or "screemer pipe " as iv heard them called ? Answers please as its got me wondering n Im worried that the next time iv have some free time I'm gona try it out n make a massive **** up , and before anyone asked iv not even looked to see if the feed pipe is before or after the turbo , if its before then obv this won't work but if anyone knows it will satisfi my curiosity , cheers
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Highly inadvisable, the EGR system works by opening a valve allowing the high pressure in the exhaust manifold to drop across the EGR pipe, causing a flow of Exhaust gases from the exhaust manifold to the inlet manifold. What you are proposing to to do remove this valve, hence the pressure will always escape, causing the turbo to lose pressure all the time resulting in rubbish drivability.
    For your plan the EGR valve itself would need to be connected. But it's all pointless as what you are doing is still technically blanking the valve off as far as the inlet manifold is concerned. Even at that you still have the gases - that now have no purpose whatsoever - flowing out still giving you the issues the valve normally give - leaking of turbo pressure. If that valve still doesn't close properly for what ever reason then you will still get bad performance.
    As said with leave as working or blank and get it remapped off.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by GazCDTI150 View Post
    Can't argue with any of that - apart from the "leave as working" bit
    Jan 2012
    largs , scotland
    Lol Yeah right after I posted that I figured the feed pipe would come off the exhaust manifold so is before the turbo so would not work and just cause the same problem as the egr sticking open only worse , maybe I should have just asked if it was post or pre turbo , ah well that's that out my head now lol , I made reducing plates and cleaned my egr the other day that worked well but still had the problem just not as bad so removed the motor part of the egr yesterday and that's sorted the loss of power and drives much better now but the light is on now and can't afford a remap just now so will have to make do and hope no new problems are masked
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Thought I would sound fair. Can't say I miss it.
    Jan 2012
    largs , scotland
    Egr valves just don't make since to me , its like putting dirt in ur engine its crazy , I remember I once sold a astra estate 1.7td when i was 18 cos I thot the turbo was on its way out but now realize it was just the egr , ah well live n learn eh ,
  1. Work Related Question
    By OPC in forum The 'Off Topic' room
    Last Post: 12th December 2010, 00:47
  2. Steering rack related question
    By MadOnVaux! in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 17:48
  3. Another Service related question!
    By adamtaylor in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 09:20
  4. another game related question
    By pogo in forum General Chat
    Last Post: 24th November 2007, 22:20
  5. Another Dragon related Question for you all
    By Marky in forum Diesel Engine related
    Last Post: 14th November 2007, 18:49
