Results 1 to 10 of 11
Thread: Power drop to head lights
    Regular Member Kcriyback's Avatar
    Jul 2011
    Edinbourgh
    Default Power drop to head lights
    Mornin all
    Vectra 2.2 direct 05 plate petrol
    When i turn my stering wheel or turn something
    Electrical on in the motor my head lights dim dull and bright
    Not a lot just enought for me to notice it and anoy me
    Any help welcomed
    Cheers all
    Jul 2011
    Edinbourgh
    No mods done to them eather cheers
    Chelmsford
    Normal mate,
    power steering is electro-hydraulic so is run by an electric motor. It puts a big drain on the alternator at low revs so the lights dim slightly.
    I think even the big boys with their fancy VXRs and 3.0 CDTis notice this one! Certainly do on my 1.8!
    Full Member Big Sig's Avatar
    perfectly normal.
    Jul 2011
    Edinbourgh
    Sorted thought i was gona be paying out
    AGAIN.
    cheers for replying
    Feb 2011
    Selby
    You can improve matters a little bit by adding extra earth wires from the engine block/alternator mount to the battery negative terminal. Ultimately the power steering can draw a hefty amount of current, and if the engine's doing less than 1500rpm, the alternator isn't really supplying a huge amount, so there will be a slight dip in the voltage at the headlights.
    But yeah - all Vectra Cs do it, nothing to worry about.
    11 Post(s)
    My headlights no longer do it since fitting HIDs. Must be somethingto do with the ballasts operating at any voltage between 9 and 30 volts and stabilising the voltage to stop the dimming when turning the steering wheel.
    Jul 2011
    Edinbourgh
    Hids ? What are thay sorry for question
    Jul 2011
    Edinbourgh
    Perfect example cheers rapala
  1. Stopping power drop to head unit
    By DNS in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 14:52
  2. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  3. 1.9 150ps CDTi Power drop in first
    By bandrew in forum Engine & Drivetrain
    Last Post: 21st August 2006, 21:19
  4. No power to head unit!!
    By jeremy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2006, 10:14
  5. Power to a Head Unit
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 16th February 2006, 10:05
