Results 1 to 10 of 22
Thread: Anyone got front parking sensors.?
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    Default Anyone got front parking sensors.?
    Has anyone got front Parking sensors factory or not,
    Any pics / measurements greatly appreciated .
    Cheers .
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Full set OEM here.
    What measurements are you after - positions ?
    If you take the bumpers off you'll find the drilling points quite clearly moulded in.
    exeter
    why would you want front parking sensors . surely you can see the front bonnet ?. your do you park with your eyes shut . lol
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    I fitted front parking sensors on mine, as said above , if you remove the front bumper the marks are there for positions..
    Sent from my iPhone using Tapatalk
    Aug 2009
    If you zoom in on this picture of mine , you can see the positions of the sensors, but they are marked on the inside of the bumper.. Hth...
    Jan 2012
    wales
    Was hoping to fit them without taking bumper off so was after the measurements . Cheers
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    TBH after doing the back with the bumper still in place it will take you longer to measure and mark up than it will to just remove the front bumper.
    Full Member spennny's Avatar
    Blantyre
    Quote Originally Posted by dilan View Post
    How do you activate them ? Switch ?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Locations - from the outside I'm guessing you'd need someone with the exact same front bumper as you have. Given how easy it is to remove the bumper, it's really not worth risking mis-measurement.
    Activation - with the OEM fit system both front and rear are active at the same time, initiated by selecting reverse or by overide switch below the hazard lights switch. System auto cancels when moving forward over 15mph.
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I retrofitted factory front parking sensors and had the wiring behind the swtch. Andy.l kindly fitted the wiring to the rec/module then had a quick tech2 session to sort them out. I already had the factory rear sensors.
  1. front parking sensors
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 14:21
  2. Front Parking Sensors
    By war222 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 13:33
