Results 1 to 8 of 8
Thread: 1.9 CDTi
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Default 1.9 CDTi
    Evening guys, quick one for you guru's, my mate has a 1.9CDTi and was wondering how to drain his engine oil, so I went to show him where his sump plug should be (going off the location of the sump plug on my VVTi) and was suprised to see a sort of splash panel/debris cover under the engine block, is this simple to remove and refit? dont have one on mine. And while im here, I presume the sump is in the same place as the VVTi?
    Cheers
    May 2007
    West Yorkshire
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    The cover had a panel u take off like 4 screw twister things and every sump on a car is at tue bottom if the engine lol
    Aug 2007
    Cupar, Fife
    Quote Originally Posted by paulvectrac View Post
    Cheers Paul, do you know why the 1.9 has the cover and others not?
    Regular Member Cruize's Avatar
    South East
    Most if not all modern cars have this undertray, Maybe yours was just missing from when u purchased it as they are not hard to break if your under there fiddling lol
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Makes the car quieter but as said not really needed.
    Regular Member blacksapphire's Avatar
    Feb 2012
    Forfar, Scotland
    Pretty sure these undertrays are only fitted to the Diesel versions but not the petrol ones---with added sound deadening to make the Diesel engines seem quieter. Had to remove mine--16 small torx screws---to give it all the once over when doing the cam belt and engine service. THEN i noticed the hatch in the middle to get at the sump plug
    Live n learn.
    It's there for drive-by sound deadening - if you look on your V5 there should be a decibel reading both stationary and moving...
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  3. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
