Thread: Camshaft housing gasket help plz
    Regular Member nicj's Avatar
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Default Camshaft housing gasket help plz
    Hey guys
    Probably a stoopid question but..Does the timing belt have to be touched to replace camshaft housing gasket on a vectra 1.9 150
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    No - just remove the top cam belt cover for ease
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yep it does and the injectors have to be removed ...so a few other gaskets and seals to buy .. is it leaking bad ? .
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Quote Originally Posted by benny View Post
    No wouldn't say it was bad
    Middlesex
    Trim : SRI
    Mileage : 100k
    Hey Benny - I didnt think you actually had to rewmove the belt off the top pulleys.. ?
    Agree on injectors for defo ~
    Feb 2006
    dudley
    Quote Originally Posted by AntSSSS View Post
    yep take the cam carrier off and the cams come with it .....
    Middlesex
    Trim : SRI
    Mileage : 100k
    I see what you mean.... Top man as always Not much you dont know about anything VX is there
    northumberland
    Vehicle : Cdti150
    Trim : Sri
    Year : 06
    Thanks for the help guys much appreciated
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    As benny says, the whole cam carrier has to come off meaning the belt first. You'd need to get 4 injector copper washers and then the carrier gasket. All of the injectors, pipes and fuel rail will have to come off too
    If it's not too bad then wait until it's needing a new timing belt but it's alot of hassle to remove.
  1. camshaft cover gasket 2ltr DTI
    By mambo in forum Diesel Engine related
    Last Post: 11th March 2010, 19:12
  2. camshaft sensor???
    By evyboy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2010, 17:18
  3. Is this a camshaft oil seal?
    By dae36 in forum Engine & Drivetrain
    Last Post: 18th January 2010, 16:10
  4. Camshaft
    By Rebellion8878 in forum Petrol Engine related
    Last Post: 3rd January 2010, 15:51
  5. camshaft
    By darren klershaw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2007, 22:18
cam carrier removal on vectra 150 cdti
