Thread: Canbus
    Regular Member m623d's Avatar
    Jan 2012
    N Lincs
    Default Canbus
    I keep reading about half canbus and full canbus
    Which is my car and how do I tell?
    2006 facelift 2.2 direct Nav Sri
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Full canbus
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Facelift Vecs are Full Canbus matey
    Jan 2012
    N Lincs
    I'm looking at getting these bulbs, will they cause probs with the canbus?
    from the 'bay
    250993297091
    Jul 2009
    Yorkshire
    They should be fine as they're standard halogen bulbs - it's the LED's (501's etc) that tend to flash...
    Jan 2012
    N Lincs
    I keep getting a bulb failure on the nsr brake light, but it appears fine, could it be a dodgy bulb?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Have you changed both red bulbs on that side?
    Jan 2012
    N Lincs
    no, not took them out, just checked they was working when the fault came up
    11 Post(s)
    Quote Originally Posted by m623d View Post
    Have you checked all the rear light bulbs?
    Should the upper tail/brake light fail, the lower tail light takes over the role of tail/brake light - so that you still have 3 working brake lights.
    Rear light positions (from the top down)
    Indicators
    Tail & brake lights
    Tail lights (which then becomes a brake light as well should the original tail/brake light fail)
    Fog light (drivers side only - UK)
    Reverse lights.
    All bulbs are 21 watt single filament bulbs. The indicator bulb has offset pins.
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. canbus/non canbus HID kits
    By glovej in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 10:00
  4. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
