Thread: Replacing track rods
    Chelmsford
    Default Replacing track rods
    Hi chaps,
    Had the parts delivered to replace both track rods (advisory on MOT due to play in joints).
    Just jacked up the car and been looking at the Haynes, but the job looks more complicated than I thought. Mentions a "special tool" required. Anyone know what this is?
    I'm no stranger to the spanners (done all the usual stuff before, springs, bushes etc) but this one looks a bit beyond me.
    Anyone got any tips? Is it really as hard as it appears?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You changing track rod ends or the whole track rod?
    If changing hole thing search in how to for changing inner tie rod.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Dec 2011
    Seaham
    You will need to get the tracking re-done once you have changed the track rods.
    Aug 2010
    Leeds
    If it's the track rod ends crack off the nut on the steering rack to track rod and take off the nut for the track rod end to front hub.
    Get a big hammer and whack the metal part where the track rod goes through into the front hub the track rod end should just pop up/ down, a ball joint splitter is preferable but even us in workshops didn't use them often.
    Once removed count the number of turns anti clockwise to remove say 14 and a half, then re fit with a little copperslip on threads.
    Wheel alignment can be checked if it was not wearing the tyres before and you take it off correct amount of turns it may be fine left alone.
    Administrator plasma's Avatar
    On the Forum
    400 Post(s)
    Engine : 150
    Mileage : 74000
    http://www.ebay.co.uk/itm/Multi-Purp...item5641bec0a1
    Thats the tool for the track rod (not the tie-end) also need to do mine as well...
    Chelmsford
    Cheers for the replies guys.
    In the end I just couldn't be bothered so called Formula One. They said it would be an hour labour to fit my parts so took it down there and... they told me there was nothing wrong with the old ones so I didn't bother!
    ****** Halfords Autocentres, going to take the car back to them and ask them to show me why they thought it was an advisory item.
    The manager at Formula One told me that my tie rods were actually suprisingly sound for a Vectra of that age and mileage...
    Problem now is that I've got to find another cause of the knocking noise when turning at low speed! (already replaced drop links)
    East Midlands
    ...DNS Quote.. "Problem now is that I've got to find another cause of the knocking noise when turning at low speed! (already replaced drop links)"
    That could be the strut top bearing,had the same on mine replaced bearing and noise has gone.
    Chelmsford
    I reckon that will be the next item on my list mate... thanks
    Might take it off tomorrow for a look and see if it's visibly worn.
  1. track and tie rods
    Last Post: 26th September 2011, 23:59
  2. Track Rods
    By biggsa in forum Suspension, Wheels & Brakes
    Last Post: 4th June 2010, 20:27
  3. Track Rod Ends or Inner Track Rods
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2010, 11:41
  4. Track rods?
    By steve1975l in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2008, 14:48
  5. Inner Track Rods....
    By Stevie-B in forum Suspension, Wheels & Brakes
    Last Post: 6th April 2007, 12:28
