Results 1 to 3 of 3
Thread: Relay question
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default Relay question
    Normally a relay uses a low amp signal to switch and supply a higher amp to the service.
    Can you use a higher amp signal to switch and supply a lower amp to the service ?
    Engine : 1.9 CDTi
    What is it your trying to do?
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 35000
    Quote Originally Posted by JagRigger View Post
    You can think of a relay as a 12V powered switch. it can switch high amps as well as low amps. They usually require around 500 mA to operate, you dont break it by feeding "high amp" signals, as they only draw as much power as they need.
  1. Can you name that Relay?
    By Journeyman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2016, 17:54
  2. Indicator Relay question?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2012, 16:14
  3. A little help with the R7 relay
    By mofozo in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 20:03
  4. Relay Question
    By mambo in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2010, 12:43
  5. Which relay is which?
    By JamesG in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2007, 19:18
