Results 1 to 10 of 14
Thread: Which uprated headlamp bulbs?
    Chelmsford
    Default Which uprated headlamp bulbs?
    Hi chaps,
    Getting a bit fed up with the crappy Vectra headlights (I swear they're worse than they used to be, do bulbs get dimmer over time?!)
    Want to put some uprated bulbs in, anyone got any recommendations?
    Don't want the expense or hassle of HIDs etc, just a quality set of extra bright bulbs that will be a straight swap.
    Sep 2010
    do a search buddy,.. this has been done to death with varying advice.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    HIDS are the way forward if you want a massive improvement in visible light on the road, as long as you get a decent set (and not a cheap and nasty set from ebay)
    If you are staying with Halogens, Osram Nightbreakers or Ring XenonMax have had good reports from other members.
    If you are going down the HID route, choose either 4300k, 5000k, or 6000k colour temperature as any higher than 6000k will likely get you pulled by plod (as they are blue-er than factory fitted HIDS).
    For reference (the higher the colour temperature, the dimmer the light):
    4300k Bright White (Brightest)
    5000k Factory Look, White/Ice Blue
    6000k White with darker ice blue tint
    Also need to point out that HID's need to be Canbus Compatible too
    Dec 2011
    Seaham
    Beleive there is also a headlight mod on the pre-facelift veccies, which raises the beam.
    Chelmsford
    Cheers chaps,
    Think I'm going to go with the nightbreakers as recommended on another thread and by Which? magazine.
    H7 is the fit for the Vectra isn't it?
    Nov 2011
    yep, H7 for dipped beam
    My nightbreakers only lasted 8 months. Waste of money, IMHO.
    Nottinghamshire
    I got Nightbreaker Plus bulbs over a year ago and both bulbs are still OK. The Plus bulbs are a development of the original ones which did have a reputation for short lifespan.
    If I was buying now, I might be tempted to give these 120% brighter Ring Xenon Ultima's a go - http://www.ringautomotive.co.uk/prod....asp?prod=2422.
    Sep 2010
    Quote Originally Posted by DNS View Post
    Hi chaps,
    This was my thinking until I bit the bullet and fitted HIDs... at £55 for the full kit, it's not that much more expensive than these so called brighter bulbs. And no hassle to be honest.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
  1. Uprated bulbs
    Last Post: 17th January 2009, 20:00
  2. 2 Uprated HID(D2S) bulbs 6000k
    By jamesr in forum Parts for sale
    Last Post: 21st March 2008, 16:51
  3. F*£$%^^ Headlamp Bulbs
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2006, 17:46
  4. headlamp bulbs
    By Dave F in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2005, 16:00
  5. Headlamp Bulbs
    By ion in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2005, 07:59
