Results 1 to 3 of 3
Thread: drivers heated seat
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default drivers heated seat
    hi all
    yet another problem with the 3.2 elite, drivers seat this time no heater!!!
    light comes on the dash switch but no heat from pads, what i want to know is how to check for voltage at the seat, and continuity of the elements, what i dont want to do is accidently unplugging the air bag connectors or set off the pre-tensioners
    so any help please
    tia
    Nov 2010
    Coventry
    I had this after hitting a pot hole at speed, just check the connectors under your seat- mine had come loose.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I had this with my 52 plate elite & it was the heater pad that was at fault .
    I stripped the seat out & tested the heater pads with a multimeter , found the bottom one was open circuit so set about tracing & repairing the fault with the help of a test light & a battery charger .
    once the faulty part was located I bypassed a 1.5 inch section of heater pad with a piece of wire & soldered it in , put the seat back together & its been fine since .
  1. Heated seat drivers backrest not heating?
    By ronnie63 in forum Bodywork & Interior
    Last Post: 4th December 2012, 14:30
  2. Replies: 42
    Last Post: 1st April 2012, 16:03
  3. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  4. Drivers heated seat not working - advice?
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 17:16
