Results 1 to 7 of 7
Thread: Fitting Patch Aerial for CD70
    Jan 2012
    Merthyr Tydfil
    Default Fitting Patch Aerial for CD70
    Hi guys, where is the best place to fit this aerial? I've looked behind the screen and space is so tight how do you guys go about fitting in such a small space and what kinda tools would you use? I was thinking under the main vent by the front of dash but how do you remove this and would it work?
    Cheers
    Jazz.
    Regular Member Dippy-Vx-line Red's Avatar
    Mar 2008
    Earlston (Scottish Borders)
    Most of the guys on here have put it in the centre speaker at the top of the dash.It is fiddly but a bit of patience should see you ok..
    Jan 2012
    Merthyr Tydfil
    By centre speaker im assuming you mean the large rectangular vent at the base of the windscreen? How do you get this out?
    Mar 2008
    Yeah thats the one..it just pops out..from there just feed the fakra end through a small gap between tbe air vents(with stereo removed)...hth
    May 2009
    South West
    A straightend wire coat hanger was the key to getting mine through.. Poked it through where the stereo goes so it poked up through the speaker hole, taped on the fakra and gently pulled it back through.
    Jan 2012
    Merthyr Tydfil
    Might work, but how did you secure it or is it just loose?
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Just sit it ontop
  1. cd70 gps aerial
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2012, 17:44
  2. Patch Aerial
    By pipamish in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2012, 08:31
  3. Aerial seal fitting wot do I ave to remove to get to the nut
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2011, 21:40
  4. aerial fitting?
    By Ben_ in forum Styling
    Last Post: 15th May 2009, 19:54
  5. will this maplin patch aerial fit CD70?
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 08:48
