Results 1 to 10 of 20
Thread: Z30DT Code:P0303 Cylinder 3 Misfire Detected
    Regular Member ben_3.0v6's Avatar
    Apr 2011
    EMEC #3
    confused Z30DT Code:P0303 Cylinder 3 Misfire Detected
    Engine; Z30DT
    Trim; SRI XP2 Nav
    Gearbox; Auto
    MY; **58 ***
    Fault Code; P0303 Cylinder 3 Misfire Detected
    Looking for some advice after this evening's panic coming out of work and starting the car.
    I have had a slight judder/erratic idle revs, develop at idle during this weekend, and this evening when leaving work the Spanner light has come on after the car sat for approx 10 secs at 1k revs and drinking at 0.8gal/hr.
    After switching the car off and starting it back up the judder/erratic idle was still there but dropped to 0.3gal/hr (normal for a cold start), and no spanner light present, (as it has been all weekend).
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Are you sure it isn't just a DPF regen?
    Apr 2011
    EMEC #3
    Positive the clue is the spanner light and the new code which wasn't there on Saturday when it was plugged in and read.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Does the car sound funny when the idle is erratic?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Using diagnostics turn that injector off and see if the idle stays same or gets worse.
    See what that injector readings are like compared to the rest.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Before you do anything, i'd change the fuel filter. Mine was behaving similar last summer (same code). It turned out i had some contaminated fuel. They're about a tenner for a new one.
    Apr 2011
    EMEC #3
    Quote Originally Posted by Celes View Post
    It sounds like its misfiring as a friends son came out and stright away said that its misfiring from listening to it. (he knew nothing about the issue).
    Apr 2011
    EMEC #3
    Quote Originally Posted by Critch View Post
    Can this be done with (OP-COM)
    Apr 2011
    EMEC #3
    Quote Originally Posted by BigWilko View Post
    I was thinking this after reading a few threads last night but then thought it maybe something else due to the misfire.
    I'm going to try some system cleaner tomorrow anything anyone can recommend? Was looking at BG244 or 2 Stroke oil?
    Last edited by ben_3.0v6; 13th February 2012 at 23:20. Reason: Can someone be so kind and merge these posts?
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by ben_3.0v6 View Post
    I find that redex just knackers my fuel filter. If the filter is clogged (not letting enough fuel through) the cleaner might not do much other than bring through more crap from the tank. It's REALLY easy to change. Failing that just take the top off the housing and see how dirty the filter is. This is what mine looked like.
  1. Z30DT Cylinder Head Gasket failed
    By ph67 in forum Y & Z30DT Specific
    Last Post: 3rd January 2013, 16:38
  2. multipul misfire 3.2 gsi p0300,p0301,p0303,p0305.
    By rayvo-gsi in forum Engine & Drivetrain
    Last Post: 11th July 2012, 17:18
  3. 0302 - cylinder 2 misfire detected
    By kristian in forum Engine & Drivetrain
    Last Post: 26th September 2011, 19:28
  4. misfire on cylinder no 3
    By WRed in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2011, 00:50
  5. Misfire on cylinder 4
    By gavman in forum Engine & Drivetrain
    Last Post: 29th June 2009, 21:58
p0303 z30dt
misfire p0303 vectra c
p0303 vauxhall vectra
vectra c PO303
p0303 vauxhall astra diesel
vauxhall insignia cylinder 3
vectra misfire no 3 cylinder
p0303 opel vectra c
z30dt injector
vectra c codes po303 302
vectra c 3.0cdti misfiring in cylinders 3 and 4
opel p0303 vectra c
