Results 1 to 10 of 15
Thread: tried but failed! An update....
    Regular Member craig-s's Avatar
    Jan 2012
    Livingston
    Default tried but failed! An update....
    removed swirl pot linkage and bonded relevant pots in place
    cleaned serviced EGR ran with it on and off, no difference
    cleaned up boost sensor
    can of 10k through the inlet
    both EGR and Boost sensor were coked up pretty bad with carbon
    The faults still there, lots of white smoke on start, car wont get past 4000RPM until warmed up. Taking off in first gear is juddery as hell. had my 5 month son in the back today and the poor wee man was vibrating! Car seems fine at higher speeds, smooth and powerful. There is a hell of a lot of engine judder at idle tho. Any advice would be greatly appreciated as I'm pulling my hair out trying to figure whats up. I'd much rather try to sort this myself. Last resort or its the garage this weekend! Cheers folks
    Oct 2009
    Aberdeenshire
    You could have some dodgy fuel or some other contamination, maybe a tank of good diesel and a bottle of redex or similar, and disconnect the battery for a while, are there any fault codes flashing up when you do a pedal test/code reader?
    Jan 2012
    Livingston
    just took the range to zero then put in a full fresh tank. No difference. Need to check the fault codes as the engine light is on at the moment due to the EGR disconnected. what and how do you do a pedal test???
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Although I'm certain the pedal test doesn't work on the CDTi. Doesn't on mine
    Check for split vac hoses too. When was fuel and air filters last changed?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    pedal test is pointless on the 1.9.
    What colour are the injector plugs? Yellow means they need to be changed to the blue type.
    Jan 2012
    Livingston
    Full service in november from Arnold Clark just before I bought it but I have looked at the pollen filter and i'm pretty sure its never been touched! All the hoses appear to be sound, followed a how 2 on that earlier. Its getting/got to the stage where I dont think i should be driving it.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by craig-s View Post
    Pedal test don't work on the diesels mate
    I use one of THESE to read my codes. Great investment for the CDTi
    Jan 2012
    Livingston
    yeah they are yellow, how do I go about changing them to the blue ones? Also whats the difference?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    search the how 2s for 3rd injector wiring
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
  1. failed CD70 update, oops
    By jamesworts in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 16:39
  2. car failed m.o.t
    By morri76 in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 18:16
  3. Failed MOT on...
    By TomiboyC in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 20:58
  4. Failed MOT
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 6th January 2011, 21:21
