Thread: vectra c 2005 1.8 Z18XE
    norway
    Vehicle : vectra c
    Engine : 1.9 cdti (120)
    Default vectra c 2005 1.8 Z18XE
    Hi i have a opel vectra c 2005 1.8 Z18XE ...
    well to make the storry short my engin is tottaly caput a big hole in the engin and broken pistons and mettal every were.
    so i need to swap the engin any big tips wood help.
    i understand that ill need to swap some components so i dont get any problems with the ecu.
    i was thinking of just lifting the engin out with out the gearboks and servopump and klima pump...
    is that posible or do i need to thake the whole crap out?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    A failed z18xe!!!!
    Anyway, nothing to worry about with the engine swap, its all just a straight swap and will work fine with your ecu etc.
    norway
    Vehicle : vectra c
    is it posible to take the engin out straight up, out off the engin bay?
    i dont want to take it out through the botom, to mutch exstra work , then it needs new engin alighnment and so on and so on.
    Chelmsford
    As long is you put a Z18XE back in, electronics should be fine.
    Never pulled the whole lot out (although most of mine has been out, it's never been all at the same time)
    By the look of things the whole lot should lift out with the bonnet taken off...
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    I would think it will come out up the way. Remove the timing belt cover will give you a few extra mm to help clear the chassis on the drivers side. Someone changed a z18xe last year but cant remember who it was now, there were pics too.
    norway
    Vehicle : vectra c
    iv taken the motor out it went ok... with only a millimeter clearens..
    i'v also contakted out opel/vauxhall scraper and ill be picking upp the new/used engin up in ca 4 day. i have to take everything from my old engin and putt it on the new one ... even the flyweel...
    anyone know if its a big hassel to change the clutch an fly weel?
    hear are som pics of the damage
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    May aswel fit a new clutch whilst it's out mate. False economy not to IMO.
    And if it's got dmf fit a new one aswel.
    Not hard to swap though.
    Especially if your competent enough to take engine out
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Double post
    norway
    Vehicle : vectra c
    Quote Originally Posted by Critch View Post
    DMF ? IMO? noob me i don't understand what that's stands for
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Tropax View Post
    its ok you do not have one so don't panic!
  1. 2005 Z18XE EML code P0100, where to start 1st to cure? Any help appreciated.
    By Jow20 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th January 2013, 12:24
  2. Vectra C 1.8 - Z18XE
    By davin4i in forum Introduce yourself.
    Last Post: 17th November 2010, 18:05
  3. Flowtec-Saugrohre (Vectra C Z18XE)
    By N-droe in forum Petrol Engine related
    Last Post: 9th August 2008, 08:39
