Results 1 to 10 of 29
Thread: 2.2direct Big problem need a good bit of advice please
    Regular Member Kcriyback's Avatar
    Jul 2011
    Edinbourgh
    Default 2.2direct Big problem need a good bit of advice please
    Hi all,
    Need a good bit of help please people im at a loss
    Ive the direct vectra 2.2 Petrol and had limp mode come on a bit
    Put it in garage for a diagnostics test n got 4 codes up of which are
    1. P0304 cylander 4 misfire. Sorted
    2. P1112 swerl flapcontrol malfunction. HELP NO IDIE
    3. P0100 mass airflow malfunction. Same no idie
    4. P1191 fuel preasure malfunction. Had a new fuel preasure
    Sensor put in by vauxhall twice due t faults
    Ive serviced it all myself all new fuel n air filters. Oil, spark plugs the lot.
    I have no idie what else t do myself without vauxhall charging me over £100
    For a wire trace has anyone got any idies at all
    Cheers all thought welcome
    Jul 2011
    Edinbourgh
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Swirl flaps are stuck in the inlet manifold and the fuel pump has gone by the sounds of it
    Jul 2011
    Edinbourgh
    Cheers paul
    Dec 2011
    Seaham
    Misfire on cylinder 4 could be as simple as needing a new spark plug, otherwise could be the coil pack on its way out.
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Ben read next to the list mate he has sorted the miss fire lmao mate
    Jul 2011
    Edinbourgh
    Cheers well put paul lol thanks anyhow ben
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    have you not got anybody local with tech2 or opcom? you could do with finding out what the fuel pressure is using the live data and seeing if the desired and actual are roughly the same after half hour of idling
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    this field remedy may be of some use to you or somebody with the right equipment
    Signum/Vectra 2003 To 2005 - Engine Type: Z22YH
    High Pressure Pump, Fuel Pressure Regulator - Defective (P1191 set)
    The customer complains that the MIL is on. P1191 us set in the ECU.
    1. High pressure pump defective, vehicle not driveable
    2. Fuel pressure regulator defective, vehicle runs in emergency operating mode
    This is caused by a defective high pressure pump or fuel pressure regulator valve. In case of customer complaint proceed as follows to verify the defective part:
    1. Check fuel feed pressure at high-pressure pump with manometer (engine running)
    Is primary feed pressure less than 3, 4 bar?
    Yes: Low pressure fuel feed failure -> check fuse, relay, intank module.
    2. Measure fuel pressure in the high pressure rail at idle by using Tech2 Datalist.
    Is fuel pressure in the high pressure rail less than 600kPa?
    Yes: High pressure pump defect, replace.
    3. Pull off connector (two-core) of the fuel pressure regulator.
    Measure the voltage of the fuel pressure sensor at 3000RPM (standing vehicle) with Tech2.
    Is Voltage greater than 1, 2V?
    Yes: Fuel pressure regulator defect, replace.
    4. Defect is not clearly allocable to one component. Proceed according to TIS 2000 service instruction.
    TIS Reference Number: E0001614
    Dec 2011
    Seaham
    Quote Originally Posted by paulvectrac View Post
    Note to self, read posts properly before offering an opinion......
  1. 2.2direct problem
    By Barnes in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2012, 17:01
  2. A good clay bar kit and abt of advice
    By philsh in forum Detailing and Car Care Discussion
    Last Post: 6th September 2012, 12:30
  3. Some good advice
    By ScotsDragon in forum Comedy & Humour
    Last Post: 14th April 2011, 11:06
  4. Wheely good advice!
    By Scalesy in forum General Chat
    Last Post: 15th November 2006, 22:16
  5. Good old fashioned Advice
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2006, 19:57
