Thread: Engine Fault Light - Water in Diesel Fuel Filter?
    Jan 2012
    St Neots
    Default Engine Fault Light - Water in Diesel Fuel Filter?
    Hi Guys,
    Since last week, the yellow car light with spanner in the middle has been staying on after start up until about 2 minutes after driving off - it then disappears. It has done this about 4 times.
    I have had the car plugged in and no fault codes were present/everything was as normal. I have read in the manual that this is displayed on diesel engines if there is water in the fuel filter?
    I have noticed the car has been really condensating when I give it some but then it has been -12 recently. Today it didn't condensate at all.
    All seems fine - no issues at all. Replaced thermostat on weekend along with vacuum hose pipes and car is running lovely.
    What do you think?
    Any help is appreciated. Thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like a glow plug or 2, mate.
    Does the spanner light only show for 2 minutes when the engine's cold?
    Jan 2012
    St Neots
    Quote Originally Posted by tony-1977 View Post
    Well I normally let the car warm up (not that the temp needle moves until driving) as I hate starting the car and going straight away in cold weather. It has only done it 3 or 4 times..
    I wouldn't say it was when engine was cold as it seems to go when I get moving?? Not sure
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If you have a faulty glow plug, you'll notice the spanner light will stay on when you start the car from cold, ie, first start of the day in the morning, and it will disappear after a few minutes. If it statys on at every start (warm or cold), then may need to investigate further a little
    Jan 2012
    St Neots
    Yeh I'll keep an eye on it. Had it plugged in straight away to check for any faults and the mechanic who is a lecturer to other mechanics (I trust him wholly) said all is well. If it was a glow plug that's no major issue am I right?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Totally right. Can only get worse tho. May lead to poor starting in the morning eventually. Keep an eye on it. Maybe a new set of plugs in the near future?
    ---Sent from my iPhone 4 using Tapatalk
  1. Replies: 0
    Last Post: 24th January 2013, 18:50
  2. engine warning light after fuel filter change
    By webtrawler in forum Troubleshooting
    Last Post: 29th September 2012, 22:04
  3. water in diesel filter
    By dunkymunky in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:07
  4. water in diesel filter, spanner light and fault code
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2011, 19:24
  5. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
vectra c engine fault light on site:www.vectra-c.com
