Thread: Radio code!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default Radio code!
    I have an old corsa with the original grundig 200 radio in it, After having the battery off i can usually put the code in according to the manual, But this time it has gone straight into safe mode, Any ideas as i don't really want to buy another radio.
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Quote Originally Posted by the-wizard View Post
    Try ebay. I paid 99p for a code. You must have the serial number off the stereo.
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    a lot of the older radios codes can be got from the serial number as the poster above states, so try your luck on ebay
    actually, before you do, pm on its way.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Its the original radio from new & i have the code for it, ive put it in on a few ocoasions when ive had the battery off, but for some strange reason this time its coming up with 'safe' & wont allow a code to be entered?.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 135000
    Have you followed the correct procedure for entering the code?
    Get into the recoding proceedure, (as per the handbook instructions), ie, turn ignition on, turn stereo off, hold down button AS and turn the stereo on. Wait until you get a beep and then release button AS. You'll then be presented with the word SAFE preceeded by a number (7 SAFE in your case). Depending on the number is how many attempts you have remaining and the waiting time before you can attempt entering the code. See table below.
    Attempt 1 - wait 10 secs. (Display shows 10 SAFE)
    Attempt 2 - wait 10 secs. (Display shows 9 SAFE)
    Attempt 3 - wait 10 mins. (Display shows 8 SAFE)
    Attempt 4 - wait 20 mins. (Display shows 7 SAFE)
    Attempt 5 - wait 40 mins. (Display shows 6 SAFE)
    Attempt 6 - wait 80 mins. (1 hr 20 mins) (Display shows 5 SAFE)
    Attempt 7 - wait 160 mins. (2 hrs 40 mins) (Display shows 4 SAFE)
    Attempt 8 - wait 320 mins. (5 hrs 20 mins) (Display shows 3 SAFE)
    Attempt 9 - wait 640 mins. (10 hrs 40 mins) (Display shows 2 SAFE)
    Attempt 10 - landfill. (Display shows 1 SAFE) ps, Re Landfill comment. Not really, but you would have to seek expert help to get it unlocked.
    Once the waiting period is over (you MUST leave the ignition turned to position 1 & stereo switched on, otherwise you'll wait forever) the word CODE preceeded by the number of attempts should then show on the display. eg, 7 CODE.
    Now enter the correct code. If you get it wrong again, the display will then say SAFE followed by one number lower than last time (and you'll have to wait however many minutes for it to time out again - see above table for waiting time)
    press AS and turn the the stereo on while AS is still pressed in, when you see - - - - take your finger off AS, say your code was 4356 press number 1 4 times, number 2 3 times , you get the idea once you have entered code keep your finger on AS youll hear a beep and it will work
    Making sure that you also have the key in the ignition, turned to position 1.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Tried as per hand book but it has never gone past 'safe', never get the chance to put the code in, my mate gave me another radio last night, same type but slightly better model 400 instead of 200 but thats the same not even going past safe??, got me stumped cos ive had the battery off before & had no problems putting the code in.
    Engine : 1.9 CDTi
    Check you have a live and ignition switched live at the stereo as it sounds like the ignition live fuse in the fuse box OR sometimes on the back of the stero when the plug goes in.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Hmmm, had a look & tested all terminals at the rear of radio (plug/block), The red's perm live but there's no switched live via ignition, although there is life at the radio/s ive tried (orig grundig 200+400,they light up), ive been given an old cd/radio & can only get it working by taking a switched live & adding it to the yellow in the plug/block, All wiring is untouched & orig from new (n rg) so i don't know if that's right but i only had the battery off so don't know why its like that unless that's how they are, also checked all fuses, So although i wanted to keep this old bus fairly original ive resorted to leaving this old cd player in for now, thanks for the suggestions folks.
  1. Radio Code
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 11th July 2012, 00:18
  2. Car Pass - Result! Key Code & Radio Code
    By mxt in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 13:01
  3. Radio code
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 19:11
  4. radio code
    By farnorth in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2008, 18:33
  5. radio code
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2007, 19:23
