Thread: I cant get my EGR out yo clean it, advice needed!!
    Jun 2011
    Herts
    confused I cant get my EGR out yo clean it, advice needed!!
    hi folks,
    I tried getting my EGR out to clean it while I was changing my thermostat but it wouldn't budge. It moved a few mm to the right then It took me ages just to get it back in position so I could get the bolts back in.
    I was wondering if i'd be able to clean the inside of the EGR If i took off the manifold the tha egr is attached to- or is is there no way of getting to the gubbings that need cleaning???
    Any advice greatly appreciated
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Im not sure about the dti ones, I know on the CDTi it's 6 bolts, two 13mm on the top and 4 10mm at the rear which secure into the manifold.
    There must be a "how to" for the dti version somewhere, I would ad a link but im on my phone
    Jun 2011
    Herts
    I've seen the how to- I unbolted the EGR and removed the cooling pipes and electrical connector but the EGR just wouldn't budge but it needs cleaning so what can i do to get at it????
    Anyone??
    Regular Member paul.sessions's Avatar
    leighton buzzard
    I think the first time I took it out I needed a soft mallet to loosen it, and keep working it left to right to remove. Was a pain in the backside.
    Jun 2011
    Herts
    I did't want to risk breaking it- i managed to move it a touch but its so tight and almost impossible to grab properly as the cooling spigots get in the way and are too weak to use as levers.
    would trying it when the car is properly warm make it easier???
    It almost blew my head as it was such a wind up!!!
    exeter
    Quote Originally Posted by paul.sessions View Post
    yeah your right a soft mallet and tap it untill it comes loose
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    It is probably the coke itself that is stopping you from removing the egr , remove the top manifold you can then get to the top of the egr .
    You should then be able to work the egr back and forwards to get it loose .
    Spraying some carb cleaner into the port should also help loosen it up .
    Jun 2011
    Herts
    cheers fellas,
    that confirms what I thought. thats a job for the next dry saturday then :-)
  1. Gave the Gsi a much needed clean!!
    By Dan. in forum Detailing and Car Care Discussion
    Last Post: 28th November 2012, 11:29
  2. Needed a clean before new wheels went on..
    By blue estate in forum Styling
    Last Post: 27th March 2012, 06:46
  3. My megane after a long needed clean
    By mspvxr in forum Non Vectra C/Signum Album
    Last Post: 4th February 2011, 21:17
  4. New mods fitted and a much needed clean.....
    By Dan_BlackSRi in forum Quick Photo Album
    Last Post: 19th January 2010, 18:32
  5. A well needed clean, and then a few pics..
    By sonic in forum Quick Photo Album
    Last Post: 2nd February 2008, 09:34
