Results 1 to 2 of 2
Thread: battery and wiring advice
    Nov 2009
    N/A
    Default battery and wiring advice
    I'm thinking about permanently wiring in an isolator switch onto the negative terminal of the battery so I can affectively disconnect it without having to physically remove the terminal.
    Looking at this for the isolator itself.
    For the additional wiring, just need to know which of these is appropriate for extending the wiring to the switch? Or is it just a case of the bigger the better?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Google "battery terminal isolator" for a simpler solution.
    For example, on this page http://shop1.actinicexpress.co.uk/sh...minals___Leads, take a look at "battery quick disconnect".
    For extending the wiring, use the same diameter as existing.
    Whichever way you go, DON'T turn the isolator key off with the engine running as you'll fry the alternator. Been there, done it, on marine installations.
  1. Advice on car wiring... please
    By Chunklamb in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2012, 20:20
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. Dvd headunit, wiring to battery!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 13:02
  4. Battery advice please.
    By crabbitoldgit in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2009, 21:44
  5. Advice on new battery please??
    By mitch1965 in forum Electrical & ICE (including SatNav)
    Last Post: 26th January 2009, 21:43
