Thread: Excess play in both tie bars? Rear Brakes 95%!
    Jul 2011
    Leeds
    Post Excess play in both tie bars? Rear Brakes 95%!
    Hi all,
    Took my car in for a recall and vauxhall had a nosey at my car. I was told that there is excess play in the tie bars, just wanted to ask what actually needs replacing. I was thinking that the tie rod ends, gator and obviously the tie rods, is that right and which brands should I use?
    Also I was told that my rear brake pads where 95% worn, would it be worth changing the discs aswel? Would I need some type of fitting kit in addition ?
    Hope someone can shed some light :-)
    Dec 2011
    Seaham
    If the discs are not worn or scored, then just change the pads.
    Lancashire
    i would'nt take any notice of vauxhall mate , every time you take it in they will find something to get some coin out of you ... just tell em you know someone who will do the work cheaper then get a second opinion off a proper mechanic
    Jul 2011
    Leeds
    Thanks for input. Now to find an honest mechanic in Leeds? Any suggestions?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Jack car up. Get someone to hold wheel at 6 and 9 o'clock position And rock wheel slightly.
    Put your hand on tie bar gaitor and feel for and play. If you can feel and movement they need changing
    Chelmsford
    Mate, as I said on another thread, I bought brand new tie-rods for my car but the garage I asked to fit them said there was nothing wrong with the old ones.
    Mine are for a 2004 hatchback, if you need them and they are the same send me a PM and you can have them cheap.
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    pm.... how much?
    Jul 2011
    Leeds
    Quote Originally Posted by DNS View Post
    Will do pal
    Quote Originally Posted by shiver2k11 View Post
    Presumably they took the wheels off and this was a visual inspection only
    The rear brake pads and discs are known to have a very poor life expectancy
    Did they give you the measurements or let you see them?
    If you are able, inspect the outer pad on each side
    If you are able to see brake pad material, then they are fine
    If you are stuggline to see brake pad material, then it may be getting near time to replace the pads
    In general you can get two or three sets of pads to the discs
    Inspect the discs, if there is severe lip on the outer edge then consider new discs, the additional cost is not that much (and vastly improves the performance)
    If you have owned the vehicle for some time, keep a service record file, or look at the receipts to see when the rear pads / discs were last replaced
    As above, take VX reports of brake pad wear with a BIG pinch of salt
    I had a report "1000 miles left front brake pads", and 5000 miles later the brake pad sensor came on, and further 1000 miles later had the pads replaced
    Jul 2011
    Leeds
    Thanks m8internet, decided to just have my mechanic look at them too much hassle for me plus no wer to work.
  1. Play in rear wheels
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 4th August 2012, 09:18
  2. Rear stabiliser link bars
    By Sambor in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2011, 18:59
  3. Play on rear wheels
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 14th April 2010, 23:19
  4. play in rear wheel
    By micks edition 100 in forum Suspension, Wheels & Brakes
    Last Post: 18th November 2009, 21:31
  5. Rear Sway Bars
    By Vectra_C_Chris in forum Handling & Braking
    Last Post: 9th June 2009, 15:39
