Results 1 to 10 of 11
Thread: dual climate control issues
    Feb 2012
    eastbourne
    Default dual climate control issues
    hi all, right i got a problem with my 3.3 gsi vectra. the climate control doesnt seem to be working correctly, the blowers are fine, but theres no heat coming from passenger side and it only blows warmish air on drivers side??????
    any ideas as too what could be causing this???
    many thanks
    11 Post(s)
    Is the engine temperature ok?
    Feb 2012
    eastbourne
    oddly enough the engine temp is fine, i cleaned the scuttle out earlier but hasnt cured the problem..
    No heat with both sides set to Hi?
    Feb 2012
    eastbourne
    only warmish air blows out of drivers side and cold out of passengers side with temp control in high??
    Feb 2012
    eastbourne
    even with the temp set to high both sides, the air still blows cold passenger side and luke warm drivers side
    You need to check the air mixture control servos are working. To check then you will need to remove the kick panels on the sides of the footwells around the centre console.
    I take it you have checked the water is hot going to the heater?
    Feb 2012
    eastbourne
    im about as mechanically minded as an orangutang :/
    what do the servos look like? and no i also havent checked for water in the heater.. again, where/what is the heater located and look like??
    Feb 2012
    eastbourne
    Feb 2012
    eastbourne
    any ideas chaps??
  1. Dual zone climate control retrofit
    By Jerom747 in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 21:09
  2. Getting inside a Dual Climate Control Panel
    By dae36 in forum Bodywork & Interior
    Last Post: 6th September 2012, 12:24
  3. Dual zone climate control
    By mikeeaston in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 19:53
  4. For Sale: Dual zone climate control switch
    By Caveman_nige in forum Parts for sale
    Last Post: 31st January 2012, 15:40
  5. Dual Climate Control
    By dae36 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2011, 16:54
