Hi,
Started with a flat spot around 1800rpm had tech 2 plugged in which shows EGR valve/MAF sensor. Cleaned the EGR valve hoping this would cure, it didnt. I unplugged the EGR valve and took it for a drive and the flat spot had gone. So I obviously presumed I needed a new EGR valve. Bought one fitted it and guess what, the flat spot automatically came back. I then fitted a air flow sensor which made no difference. Ive subsequently fitted the fiat blanking plate which helped the problem for a while. The car now seems to be getting worse again.
Could anyone suggest something to try as im struggling. I cant understand how the misfire is helped by blanking the EGR when fitting a new one only makes it 10 times worse.
P.S Ive cleaned boost sensor.
