Thread: Changing battery
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Default Changing battery
    Might sound like a daft question but is there anything I should know when I change my car battery tomorrow the cold weather has killed it, I used to leave the ignition on when I had my vec B so the alarm didn't go off do I need to do this on the C.
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Radio code, clock etc
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Shouldn't need a code for the facelift Phil, I think thats only for half can HU's. But you will have to make the windows re-learn the one button up and down. Just press down, keep its pressed until you hear a beep, then hold up and again wait for the beep. Oh, yea, the same for th sunroof if your lucky enough to have one.
    Aug 2011
    Letchworth, Herts
    If I don't leave the ignition on won't the alarm go off
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by dannycturbo View Post
    No mate, you'll be fine, its different than the Vec B.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    I changed my old vec one and the windows were still ok after think if ya quick with the swop over you will be ok mine was a 06 plate
    The instructions for disconnecting the battery to prevent the alarm sounding are as follows.
    Switch on and off the ignition. Disconnect battery within 15 seconds of doing so.
    Best to slacken off the batt terminals first so you're not fighting against time with the spanners.
    Aug 2011
    Letchworth, Herts
    Job done also put a battery bag on while I had the battery off, also got a new remote battery for my key fob so should all be ok now :-)
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. P-Reg Omega - SAFE after changing battery
    Last Post: 11th January 2009, 15:54
  4. Spanner light after changing battery
    By gtr1000 in forum Engine & Drivetrain
    Last Post: 10th December 2008, 21:40
  5. Changing Battery in Immobilser/Alarm Unit
    By skippy in forum Vectra C / Signum Troubleshooting
    Last Post: 8th February 2008, 16:35
