Results 1 to 10 of 24
Thread: How much to put an electric shower in? Nottinghamshire
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Default How much to put an electric shower in? Nottinghamshire
    Looking to have a shower installed. But struggling to get a good price.
    What i think is needed
    10mm twin and earth ran from the fuse box down stairs up in to the loft approx 10 to 15 metres plus a switch and fuse
    A Shower to be installed with a chrome pipe from the loft into the bathroom.
    Had some silly quotes over the 1k.
    Any ideas or anyone local willing to come a do the job if the price is right?
    Jan 2012
    nottingham
    give me one day mate and i find for you some people who do this very cheep
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    If you need the cable I'm guessing you don't already have an existing shower.
    The easiest method is to bring the cold feed from under the bath and up into your shower.
    Depends how hard it is to route the cable, do any walls need chasing, how many floor boards need lifting etc... ? (routing 10mm is a pain)
    You could save on costs by creating a route for the cable for yourself so it's easier for the spark. Any good with plumbing? You could source the cold feed and clip it up the wall to were the shower is going to save on costs.
    I'm a plumber but not a spark, probably charge appx £120 labour only to screw and pipe up a shower, materials ontop of that.
    A few hours of the sparks time I'm not sure maybe £300 odd?
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Quote Originally Posted by john506 View Post
    As the bathroom had been retiled before i moved in i want the least amount of pipe on show, so thats why i was thinking of having it come down from the ceiling.
    I did buy a thermo mixer tap but there isnt enough pressure between the tank and tap. Most of the plumbers said its a pain trying to install a pump as theres not enough room in the airing cupboard to put it and it would be tight under the bath and couldnt decide if i should have a single or double feed as the cold is on the main supply.
    And the plumber whose quote i accepted has never came back to do the job, when i ring him, he says is off work due to sickness, this has been going on for over three months.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Quote Originally Posted by mark-signum View Post
    Thanks matey
    Jan 2012
    nottingham
    pm send
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    msg sent
    Midlands Mod Shop - NFFC.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    depends on what kw the shower is you could get away with a 6mm as its under 20/25m
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    As a spark and doing such jobs its difficult to give a price as depends on a lot of factors. As mentioned, 10mm is an absalute pain in the arse, even with trunking, unless you got a perfect strait run its just annoying as hell.
    If it was strait forward you would be looking at £250+ for the Electrical side.
    To save a few, there is nothing against you taking advice and running the cable yourself, from the C/U to the Switch then to the Shower, but dont be suprised if the Electrician is then difficult to find to finish it off.
    Bathrooms are a zone covered by the whole Part P Saga, So should be a registered spark (Nic, Nappit all them).
    If you supply more info, im sure people could provide a more accurate price/amount you should be paying.
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Quote Originally Posted by paulvectrac View Post
    Was told to go for the biggest shower i could get like the 10.5 or 11.5kw as would provide a better shower, but also been told to have a pump to go with my mixer tap.
    All i want is a shower that will work and a reliable person to install when they say
  1. Four Wheel Alignment ?? Nottinghamshire / South Yorkshire Area
    By phil67 in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2012, 20:51
  2. 2 Bed End Terrace, Bingham, Nottinghamshire
    By aaruck in forum General items for sale
    Last Post: 20th August 2008, 14:48
  3. Electric Shower Problem!
    By aaruck in forum The 'Off Topic' room
    Last Post: 25th July 2008, 16:30
  4. 3.2 Re-Map in Nottinghamshire
    By aaruck in forum Petrol Engine related
    Last Post: 19th July 2008, 09:29
  5. Window tint in the North Nottinghamshire area
    By Dazlear in forum Vectra C / Signum Car Chat
    Last Post: 21st September 2007, 21:53
