Results 1 to 10 of 20
Thread: Radiator reservoir cap on to tight.advice.
    Jun 2009
    Middlesex
    Default Radiator reservoir cap on to tight.advice.
    Went to top up antifreeze in expansion bottle only to find cap is difficult to undo.Undid as much as i dare but either cap or threads of expansion bottle i feel will break if i go anymore.Anyone had this problem ?
    Any idea's ?
    Thanks Dobs.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Did it move at all? Could try pouring some boiling water over and see of it helps.
    Regular Member tosh23's Avatar
    HULL
    The radiator expansion tank or burp tank ( same thing) is very cheap at main dealers and really really easy to swap...If you snap the neck/threads then don't worry too much, Just get a new one and be a happy bunny..
    Please note...
    the expansion tank/ burp tank is not usually on the shelf, it took vauxhall main dealers 2 days to get it, so before using brute force and ignorance make sure they have one on a shelf for you to pick up if needed....Tosh
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Try to brake the seal when engine hot but do not remove it just take cared.
    Jun 2009
    Middlesex
    It has not been undone for a long time and it looks like there is i seal on the underside of the yellow cap which is sticking within the filler neck.Yes the cap is turning but is not rising up the threads.
    If i have to replace the expansion bottle ,how do i go about bleeding air locks/air from the cooling system.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Shouldnt have a problem if only replacing the bottle.
    Best thing is clamp off pipe at the bottom, a rag and some mole grips will do fine.
    Unclip bottle from holder (lift front end up and pull out)
    Remove 2 smaller pipes. And plug the ends,
    Undo clip from underneath and simultaneously pull pipe and twist bottle upside down
    This will stop you spilling bottle of coolant everywhere and also mean you can use it again.
    Fit new bottle.
    Fill to cold marker line.
    Start engine and whilst runningnup to temp
    Pump bottom radiator hose. And that'll get rid off the air. It's not strictly needed but better to male sure
    Hth
    Adam
    Jun 2009
    Middlesex
    Thanks Adam.If i clamp all the pipes where you say and squeeze the bottom radiator pipe do you think there is little risk if air entering the cooling system.
    Dobs.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Tbh you wouldn't even need to pump the hose.
    I did same technique of clamping pipe etc other week. Repeatedly whilst pressurising system trying to find coolant and never pump my hose and didn't have a problem.
    But by squeezing the bottom hose even just once it'll force that tiny air gap back into the bottle and you'll be fine
    Jun 2009
    Middlesex
    Is there only one type of orange/pink antifreeze that Vauxhall sell.I want to use orginal Vauxhall spec.
    Thanks.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah vauxhall onlymuse one. It's about 4.50 a litre.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. Buying a radiator advice
    By Zakstarr in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2012, 23:00
  3. Vacuum reservoir problem
    By Gethda in forum Engine & Drivetrain
    Last Post: 27th February 2011, 17:21
  4. Replies: 15
    Last Post: 2nd August 2009, 00:11
  5. Radiator mount popped out over pothole! Any advice on how to get back in?
    By nickyg in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2009, 11:28
